New Reply
Mathematical Induction
Share Thread
Jan23-11, 12:53 PM   #1
Consider the sequence of real numbers x1, x2, x3,.... defi ned by the relations x1 = 1
and xn+1 =[tex]\sqrt{1 + 2xn}[/tex]
1. Use mathematical induction to show that xn+1 > xn
for all n [tex]\geq[/tex] 1.
3. The attempt at a solution
I'm a bit thrown off by this question because it seems very obvious that it would be greater. if x1=1 is it safe to assume that xn=n? and if so I feel like this proof is stupid cause it shows right in front of you that its greater. any help is great thanks.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan23-11, 01:50 PM   #2
Mentor
Fixed your LaTeX.
Quote by AerospaceEng View Post
and xn+1 =[tex]\sqrt{1 + 2x_n}[/tex]
The obviousness (or not) is irrelevant to what you need to do, which is to prove this statement by induction.
You are given x1 = 1. What is the value for x2? If x2 > x1, then use that for your base case.
Next, assume that xk > xk - 1 (the induction hypothesis), and use that assumption to show that xk + 1 > xk. If you can do this, you will have proved that the statement is true for all n >= 1.
Jan23-11, 02:40 PM   #3
The proof is not stupid! Lol engineers!
Perform the substraction [tex] x_{n+1}- x_n[/tex] then show the substraction is > 0. Hint: rationalise and use the fact that a^2 >0 for an real number a.
Jan24-11, 03:51 AM   #4
I'm I allowed to say that xn+1 is the same thing as xn + x1 cause i feel I can't and if I can't I feel so limited.
Jan24-11, 03:59 AM   #5
Recognitions:
Gold Membership Gold Member
But that's not true.
xn+1 is clearly shown to be [tex]\sqrt{1+2x_n}[/tex].
So...
[tex]x_{n+1}-x_n = \sqrt{1+2x_n} - x_n[/tex]
So you need to prove that the above equation is always greater than 0, given x1=1.
Jan24-11, 04:15 AM   #6
okay so I think i see where this is going. what i've done so far is i've taken the RHS and multiplied it by itself just with a positive between the terms, to give me 1+2xk-xk2
But i feel like i've done something wrong because i haven't used x1=1 as of yet..
Jan24-11, 04:20 AM   #7
Recognitions:
okay so I think i see where this is going. what i've done so far is i've taken the LHS and multiplied it by itself just with a positive between the terms, to give me 1+2xk+xk2
and i can factor this to give me (x+1)2
Is that good enough to show that it's always greater than 0. and then ill just plug this mini proof into my main proof.
Considering that x_k itself is always greater than 0, that should be enough. But I'll wait for a second opinion on that.
Jan24-11, 04:38 AM   #8
now if i work with the left hand side I get xk+12-xk2 and i can cancel the -xk2 on both sides to give me:
xk+12=2k+1
and i feel im stuck again and where does the x1=1 come into play?
Jan24-11, 06:16 AM   #9
Recognitions:
Homework Helper Homework Help
the x_1 comes into play when you show that x_2>x_1 which is the initial step when you should have done first.
Jan24-11, 09:31 AM   #10
Mentor
xk+12=2k+1
See post #2.
New Reply
Similar discussions for: Mathematical Induction
Thread Forum Replies
Difference between Strong Induction and Mathematical Induction? Calculus & Beyond Homework 5
Mathematical induction Math & Science Software 0
Mathematical Induction Math & Science Software 3
Help on Mathematical Induction Math & Science Software 8
Mathematical Induction Math & Science Software 4
