Thermodynamics: Change in entropy of a falling ball
The discussion revolves around the change in entropy of a falling ball in a closed isolated system, transitioning from an initial height (state A) to a lower height (state B). Participants explore the implications of energy loss and the nature of the process, questioning whether it is reversible or irreversible.
  • Participants discuss the relationship between potential energy loss and entropy change, with some suggesting that the system's isolation implies no heat transfer and thus no change in entropy. Others consider scenarios where the ball could bounce or interact with a spring, raising questions about energy dissipation and reversibility.
The discussion is ongoing, with various interpretations being explored. Some participants suggest that the entropy remains unchanged, while others propose that it increases due to potential energy being converted to heat. There is no explicit consensus, and participants are encouraged to seek clarification from a Teaching Assistant or professor.
Participants note the ambiguity in how the ball loses energy and the assumptions regarding heat transfer. The problem's constraints and the nature of the system are under examination, particularly regarding the definitions of reversible and irreversible processes.
death_knight
In a closed isolated system, a small rigid ball is held at height h1, which we will call state A. By remote control a pin is pulled and the ball is released. It falls to height h2, called state B. Calculate the change of entropy S of the system. Is it a reversible or irreversible process?
Delta S = Delta Q/T
My attempt is that since the system is isolated that means no heat is transferred and the entropy is not changed at all.
But again, since the position of the ball is now lowered, it also means it has lost some potential energy, so change in Q can be related to change in energy which can be mg(h1-h2), with T being constant. So am not sure which one is the right answer.
Also sometimes I think it is an irreversible process because external work will be needed to bring the ball back to its original height but then I also get confused that it might be reversible process because it's an closed isolated system.
Thanks for your help in advance!
The ball seems to be still falling at H2. In this case it would appear the since the ball can still do the same work it could at H1, I'd say the entropy is unchanged. If you said the ball bounced off the bottom, there'd be a little heat there and the ball would loose the ability to recoil back to H1. In that case you'd have an entropy increase.
It's reversible if the ball can bounce back up to H1. It's rigid so that might work. If the ball was made of clay-filled leather you'd imagine it would be quite irreversible.
Well I thought, the ball kind of stays at the second position. I agree to your theory but again this notion of mechanical work done in this process bugs me a lot. What about the loss in potential energy of the ball?
Note: Note that height h1>h2, the initial height is greater than the final height.
It is not a very good question because we don't know how the ball loses its energy. If it landed on a spring and the spring energy held by another pin at its maximum point, there would be no heat produced and no change in entropy. The ball could go back to its original height by releasing the spring. So it is reversible.
Having said that, I suspect that you are supposed to assume that the change in potential energy is lost as heat.
AM
AM
Thanks Andrew!
So you suggest the answer would be that "Entropy doesn't change" and the process is "reversible"
Right? I am going to confirm that with the Teaching Assistant or the professor himself soon, and if I get something from them, I'll share here :)
death_knight said:
Thanks Andrew!
No. I am not sure. I think the person who posed the question may want you to assume that the change in potential energy is transferred to the surroundings as heat, in which case, the entropy increases by the amount mg(h1-h2)/T where T is the ambient temperature.
AM
  • · Replies 20 ·
