New Reply
Need example of a continuous function map cauchy sequence to non-cauchy sequence
Share Thread Thread Tools
Jan23-11, 06:20 PM   #1
I need a example of a continuous function f:(X, d) -> Y(Y, p) does NOT map a Cauchy sequence [xn in X] to a Cauchy sequence of its images [f(xn) in Y] in the complex plane between metric spaces.
2. Relevant equations
If a function f is continuous in metric space (X, d), then it continuous at every point in X.
Definition of a sequence converges to a point in metric space:
If {xn} -> x, then for all e>0, there exists an N such that d(x, xn)<e, for all n<= N
Definition of Cauchy sequence in metric space:
- {xn} is a Cauchy sequence if for all e>0, there exists an N such that d(xn, xm)<e, for all n, m <= N
- Every convergent sequence in metric space is a Cauchy sequence.
3. The attempt at a solution
I have counterexample in mind in R but not complex plane in metric space though.
Let f:R-{0} -> R-{0} defined by f(x)= 1/x, so f(x) is continuous on all domain.
Let {xn} = 1/n, then {xn} converges to 0 and therefore is a Cauchy sequence in R–{0}, but its image f(xn) = 1/xn = 1/(1/n) = n diverges, therefore is NOT a Cauchy sequence.
But I need an example of a continuous function f:(X, d) -> Y(Y, p) does NOT map a Cauchy sequence [xn in X] to the Cauchy sequence of its images [f(xn) in Y] between complex planes in the metric spaces?
Any suggestions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Jan23-11, 06:29 PM   #2
1/x?
EDIT: nm i didnt read the whole post
New Reply
Thread Tools
Similar Threads for: Need example of a continuous function map cauchy sequence to non-cauchy sequence
Thread Forum Replies
cauchy sequence Calculus & Beyond Homework 4
norm, delta function, cauchy sequence Calculus 0
Cauchy sequence Calculus 6
cauchy sequence Calculus & Beyond Homework 17
Cauchy Sequence... Calculus 1
