Register to reply
Shape of titration curve in vol (NaOH) vs vol (HCl)
by matthew77ask
Tags: curve, naoh, shape, titration
Share this thread:
matthew77ask
#1
Jan23-11, 09:35 PM
P: 45
In an experiment titration. The NaOH was added drop wise into HCl in a conical flask.
The number of drops of NaOH was recorded against the varied volume of HCl in the flask.
A graph was to be plotted of number of drops of NaOH on the y-aixs to Volume of HCl on the x-axis.
What would the shape of the graph looks like?
The students got straight lines and s-curves...
(OK it was not an accurate experiment but was used to test their other skills sets)
Many thanks
Additional Details
If the graph is pH vs volume added, then it is an S-curve, but now it is volume (number of drops) of NaOH (on y-axis) plotted against the volume of dil HCl... hence the confusion
Many thanks.
PS: I suspect a straight line as y = mx, as the number of moles for neutralisation should increase proportionally with the volume of acid...
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
symbolipoint
#2
Jan23-11, 10:42 PM
HW Helper
PF Gold
P: 2,799
In the experiement, "drops" of NaOH were added to the HCl solution; was volume of NaOH measured, or were just the drops counted?
That description is not reasonable. If you are adding drops of NaOH titrant to an initial volume of HCl solution, the volume of HCl solution is increasing, yes, but it is both being neutralized with the NaOH, and the total volume is increasing in the flask; in other words, the concentration of the HCl is descreasing.
The graph of pH as "y" with the volume of added NaOH as "x" would give a 'S' shape graph. The graph of volume of added NaOH versus the volume of HCl in the flask---- explain what you really mean! There is a volume of HCl SOLUTION in the flask until it is all neutralized with NaOH, beyond which no more HCl is in the flask. Do you really mean CONCENTRATION of solution in the flask? If so, then this would be a graph of a line.
Borek
#3
Jan24-11, 02:57 AM
Admin
Borek's Avatar
P: 23,402
pH measurement is not mentioned, so it doesn't sound to me like a titration curve. More like confirming simple and obvious stoichiometry.
matthew77ask
#4
Jan25-11, 08:06 PM
P: 45
Quote Quote by symbolipoint View Post
Sorry - I mean the plot of the initial volume of HCl on x-axis and the number of drops of NaOH added. ie Not the total volume (NaOH + HCl).
Hence my reasoning is that we are plotting the number of moles required for neutralization.
So it should be a y = mx straight line. Am I correct?
[my experiment graph is straight line]
symbolipoint
#5
Jan25-11, 08:19 PM
HW Helper
PF Gold
P: 2,799
Quote Quote by matthew77ask View Post
What is the use of making a plot of volume of NaOH titrant versus initial volume of HCl solution? This would be a line with zero slope (just horizontal line). What are you really trying to measure and graph? Moles of NaOH titrant versus volume of initial amount of HCl solution? Same kind of graph: horizontal line.
OR do you mean you measured amount of NaOH needed to neutralize DIFFERENT initial volumes of HCl solution? This kind of graph really would give you a line with a positive slope (going upward as you go from left to right along the x axis.)
matthew77ask
#6
Jan25-11, 09:47 PM
P: 45
I am very sorry for the lack of clarity in written english language.
Yes sir, this is what it means:
ah - many times, when we speak we can understand - but when we write - it has to be more specific !
many thanks - got your answer... straight line with positive slope passing thru (0,0)
Cheers!
Register to reply
Related Discussions
Quantitative Titration - NaOH and HCl Biology, Chemistry & Other Homework 9
Chem II Lab- Titration of Vinegar with NaOH Biology, Chemistry & Other Homework 2
Titration of H2SO4 and NaOH Biology, Chemistry & Other Homework 2
What's differance between J-shape cure & S-shape curve Biology, Chemistry & Other Homework 1
Titration of NaOH and HCl... need help Chemistry 6
