What is the Final Speed of a Horizontally Launched Rocket in Space?
The final speed of a horizontally launched rocket can be calculated using the ideal rocket equation: V_f = Isp * g_0 * ln(m_i/m_f), where Isp is the specific impulse, g_0 is the acceleration due to gravity at sea level, m_i is the initial mass, and m_f is the final mass. For the Pegasus-3 rocket, with a gross mass of 985 kg and an empty mass of 203 kg, the specific impulse is 293 seconds. Calculating the final speed requires considering each stage of the rocket separately, as the statistics provided pertain only to the third stage. The discussion also highlights the potential for launching payloads to Low Earth Orbit (LEO) using a modified Rutan VSS Enterprise spaceship.
  • Understanding of the ideal rocket equation
  • Familiarity with specific impulse (Isp) and its significance
  • Knowledge of mass ratios in rocketry
  • Basic principles of orbital mechanics
  • Research the ideal rocket equation in detail
  • Learn about the specific impulse of different rocket engines
  • Study the mass ratio calculations for multi-stage rockets
  • Explore the physics of launching payloads to Low Earth Orbit (LEO)
Aerospace engineers, rocket scientists, students studying rocketry, and anyone interested in the mechanics of space launches will benefit from this discussion.
Vitall
We got rocket 200km above see level. Horizontal speed is zero. So, it eventually fell on Earth. We will lunch rocket horizontally. What the final speed it will reach?
Pegasus-3 Gross Mass: 985 kg. Empty Mass: 203 kg. Thrust (vac): 3,525 kgf. Isp: 293 sec. Burn time: 65 sec. Propellants: Solid Isp(sl): 240 sec. Diameter: 1.0 m. Span: 1.0 m. Length: 2.1 m. Country: USA.
Should be enough data. If you provide an equation, how you figure out speed, it will be greatly appreciated(so I can calculate speed for different types of rockets). Sorry, not a rocket scientist (tried google, but felt). Excuse my English.
Hi Vitall, welcome to PF!
The ideal rocket equation will give you the results without taking drag or gravity losses into account.
[tex]V_f=I_{sp}*g_0*ln(\frac{m_i}{m_f})[/tex]
g_0 is the sea level acceleration of gravity, Isp is the specific impulse of the engine (a measurement of the "effectiveness" of the motor), m_i is the fueled or gross mass, m_f is the empty mass.
The statistics you have listed are only for the third stage of the pegasus rocket, most likely taken from http://www.astronautix.com/stages/pegasus3.htm . To compute the final speed of the whole rocket, you'll need to take each stage separately, adding the fueled mass into both the final and initial masses, and then dropping the lower stages' mass.
Hope all that made sense. Your english is fine... much better than my attempt at your native language, I'm sure.
Thank you Enigma.
That is perfectly answering my question. The theoretical question was, if we place third stage on Rutan VSS Enterprise spaceship, instead of tourists, what mass we can put on LEO. After some calculation (another forum), we calculated that it might be possible to lunch 20kg/25kg on LEO, but we will need a VERYVERY good hydrogen based third stage, and that is not truly realistic. Thank you for your help once again.
11K
