Elegant solution to this vector equation?
  • Context: Graduate
  • Thread starter Thread starter monea83
    Vector
The discussion focuses on finding a plane that contains a line \( l \) and intersects a given plane \( E \) at a specified angle \( \alpha \) in \( \mathbb{R}^3 \). The solution involves determining the normal vector \( \hat{x} \) of the unknown plane using the equations \( x^Tx = 1 \), \( x^Tn = \cos \alpha \), and \( x^Td = 0 \). A more elegant matrix-vector representation of the solution is proposed, leading to the expression \( \hat{x} = \frac{\cos\alpha}{1-(\hat{n}\cdot \hat{d})^2} [ \hat{n} -(\hat{n}\cdot \hat{d}) \hat{d} ] \pm \frac{\sin\alpha}{\sqrt{1-(\hat{n}\cdot \hat{d})^2}}~ \hat{n}\times \hat{d} \), where the sign depends on the orientation of positive \( \alpha \).
  • Understanding of vector algebra in \( \mathbb{R}^3
  • Knowledge of unit vectors and their properties
  • Familiarity with matrix operations and dot products
  • Basic concepts of angles between planes and lines
  • Explore advanced vector calculus techniques for plane and line intersections
  • Study matrix representations of geometric transformations
  • Learn about the properties of cross products in \( \mathbb{R}^3 \)
  • Investigate applications of these concepts in computer graphics or physics simulations
Mathematicians, physicists, and engineers working with geometric problems in three-dimensional space, particularly those interested in vector equations and their applications in various fields.
monea83
Given are a plane E and a line l in general position. I need to find a plane that contains l and intersects E at a given angle [tex]\alpha[/tex]. All of this happens in R^3.
The interesting part is to find the normal of the unknown plane, let us call this normal x. I came up with the following equations:
[tex]x^Tx = 1[/tex]
[tex]x^Tn = \cos \alpha[/tex]
[tex]x^Td = 0[/tex]
in which n is the unit normal vector of the given plane, and d is the direction vector of l.
(1) says I want a unit vector, (2) says the planes need to intersect at a given angle, and (3) says the plane needs to be parallel to the given line.
These equations can easily be solved by writing them out in component form with x=(x1, x2, x3) and doing some substitutions, which will yield a quadratic equation in one of the parameters.
However, I am wondering if there is a more elegant way to express the solution - something more matrixy-vectory? The equations look simple enough...?
If the line is normal to the plane E, then the plane we're looking for is not uniquely defined. So we may assume that [tex]\hat{n}\cdot \hat{d} \neq 1[/tex]. In this case, [tex]\hat{n}, \hat{d} , \hat{n}\cdot \hat{d}[/tex] span [tex]\mathbb{R}^3[/tex]. We can solve your conditions to find the normals
[tex]\hat{x} = \frac{\cos\alpha}{1-(\hat{n}\cdot \hat{d})^2} [ \hat{n} -(\hat{n}\cdot \hat{d}) \hat{d} ] \pm \frac{\sin\alpha}{\sqrt{1-(\hat{n}\cdot \hat{d})^2}}~ \hat{n}\times \hat{d}.[/tex]
The sign depends on the orientation of positive [tex]\alpha[/tex].
This looks interesting... I tried to reverse engineer your solution, but didn't quite get there. How do you use the fact that the vectors you mention span [tex]\mathbb{R}^3[/tex]?
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 23 ·
