Energy capacity to do work (frames of references)
The discussion revolves around the concept of energy, particularly kinetic energy, and its dependence on the frame of reference. Participants explore whether energy is an intrinsic property of an object or if it varies based on the observer's motion. The conversation touches on theoretical implications, definitions, and the relationship between energy and mass.
  • Some participants question how energy can be defined as a measure of an object's capacity to do work when it appears to depend on the observer's frame of reference.
  • Others argue that kinetic energy is not an intrinsic property of an object, as it varies with the frame of reference, and thus cannot be equated to mass.
  • A participant suggests that total energy in a closed system remains constant regardless of the frame of reference, highlighting the conservation of momentum and energy conversion processes.
  • There is a discussion about the implications of defining kinetic energy without specifying the frame of reference, with some asserting that it is insufficient to state an object's kinetic energy without this context.
  • Some participants propose that while kinetic energy is related to mass through the equation KE = 1/2mv^2, it does not equate to mass itself, emphasizing that the relationship is dependent on relative velocity.
  • One participant suggests that kinetic energy can be related to mass through proportionality, indicating that changes in kinetic energy and velocity occur at a proportional rate across different frames of reference.
Participants express differing views on whether energy is an intrinsic property of an object or if it is contingent upon the observer's frame of reference. The discussion remains unresolved, with multiple competing perspectives on the relationship between energy and mass.
Participants highlight the importance of specifying the frame of reference when discussing kinetic energy, indicating that the lack of a defined reference can lead to ambiguity in energy values. There are also unresolved questions regarding the definitions and implications of equating energy to mass.
madah12
I have a problem understanding how we can say that an object has energy of x joules because energy depends on the frame of reference right ? I mean let say a bird is moving with velocity of 5 m/s if I were a stationary man I would observe that it has a kinetic energy but if I were moving with 5 m/s then it would have zero energy, so how can energy be a meassure of the capacity of an object to do work and why is it considered to be the same thing as mass as being a property of the object itself if it depends on the frame of reference?
If you and the bird are both moving at 5 m/s with respect to the ground, in the same direction, how can the bird do any work on you?
If you take into account all the objects affected by a change in energy, then the total energy for that closed system remains constant, regardless of the (inertial) frame of reference. Ignoring losses to heat, potential energy (electrical, chemical, gravitational) can be converted into kinetic energy. Momentum of the system will also be conserved (the center of mass remains moving at constant velocity or zero).
For example, imagine a rocket in outer space. The chemical energy of the fuel is used to accelerate the rocket and the exhaust fuel. The total increase in kinetic energy of rocket and fuel are equal to the chemical energy of the fuel converted (ignoring losses to heat), and are the same regardless of the frame of reference.
A similar analogy could be made for a car accelerating on the earth, as long as you consider the car and the Earth as the closed system where both car and Earth experience an energy change when the car's engine performs work (chemical to kinetic energy convertion).
well it can't so what I am asking is that whether energy like mass is a property of the object itself rather than affected by the one who measures it or does it mean the capacity to do work on a certain object and changes by the change of the motion of the object? if so then how could it be equated to mass?
also is it insufficient to say an object has kinetic energy of some value without saying with which references it was taken from? I mean the bird had different kinetic energies in the two scenarios which one is to be considered?
Kinetic energy depends on the frame of reference; it's not an intrinsic property of an object.
It isn't.
Right. To say an object has a certain KE is meaningless if the frame of reference is not specified. (Of course, often it's clear from the context what the frame of reference is.)
You choose the frame of reference most useful for your purpose. The physics doesn't change.
Kinetic energy isn't equated to mass? KE = 1/2mv^2 seems to equate to mass by 1/2 the relative velocity squared is how to me...It is equated to mass by accounting for the velocity, at the same relative velocity two equal masses have equal kinetic energy...thus (mass = KE*X) mass is always proportional to KE, the variable proportionality(X) being (the relative velocity squared) to (2)...I would say
KE doesn't 'equate' to mass, but to 1/2mv^2. Big difference! Obviously it depends on the reference frame.
Definition of EQUATE
transitive verb
a : to make equal : equalize b : to make such an allowance or correction in as will reduce to a common standard or obtain a correct result
: to treat, represent, or regard as equal, equivalent, or comparable <equates disagreement with disloyalty>
It is made equal, equalized, by a variable proportionality we can correct KE to give the result of mass by dividing it by 1/2v^2.. to use an example, At the same relative speed, we have the same mass and the same KE, if you have relative velocity compared to me, and I don't know your mass, but I could measure you KE, I could equate that to you mass by allowing for your velocityTo be equatable just means to be proportional...imho
Did you read the thread to see what the OP might have meant by his statement?
Reread the definition that you quoted.
Seems to me he is asking How can in be equated to mass if it is relative to your frame of reference... And the answer is it can be because it is dependent on only two quantities, mass and velocity, since velocity is relative to the reference frame, KE will be proportionately relative. i.e. the relative KE and the relative v change at the same rate if you were to compare in two different reference frames. that being the case, the mass will be the same if you divide relative KE by 1/2relative velocity^2 even though they are both relative to the frame of reference
change at the same rate is a bad wording, they change at a porportional rate...hah
but it probably is my vocabulary that is lacking...it maybe cannot be equated, but it can be related?
  • · Replies 24 ·
  • · Replies 54 ·
  • · Replies 18 ·
