Welcome to the Board: Quick Questions on Physics & Chemistry
  • Context: Undergrad
  • Thread starter Thread starter Purduenub03
The discussion focuses on two physics problems involving rotational motion and gravity simulation. The first problem requires calculating the rotation frequency of a space station with a radius of 120 m to simulate Earth's gravity, leading to a frequency of approximately 0.0455 revolutions per second. The second problem involves determining the maximum distance a coin can be placed from the center of a record rotating at 33.3 rpm, given a static friction coefficient of 0.3. The solution involves equating the centripetal force to the maximum static friction force to find the distance.
  • Understanding of centripetal acceleration and its formula.
  • Knowledge of static friction and its coefficient.
  • Familiarity with rotational motion concepts, including revolutions per minute (rpm).
  • Basic algebra for solving equations involving forces and motion.
  • Study the principles of centripetal force and acceleration in detail.
  • Learn how to calculate rotational frequency from linear velocity.
  • Explore the effects of static friction in rotational systems.
  • Practice solving problems involving rotational dynamics and forces.
Students and enthusiasts of physics, particularly those interested in mechanics and rotational dynamics, as well as educators seeking to enhance their understanding of these concepts.
Purduenub03
First off, I'm new to the board and want to say hi to everyone! I hope i can give and take from this site, i should be helpful in the chem forums, but physics is not my best. I have 2 quick questions if you could help me that'd be great.
A space station is shaped like a ring and rotates to simulate gravity. If the radius of the space station is 120 m, at what frequency must it rotate so that it simulates Earth's gravity? [Hint: The apparent weight of the astronauts must be the same as their weight on Earth.] - in rev/s
I did the following and got it wrong
9.8 = V^2/120, found v = 34.29m/s
34.29 / 2*pi*120 = .045 rev / s
Where have i gone wrong?/
A coin is placed on a record that is rotating at 33.3 rpm. If the coefficient of static friction between the coin and the record is 0.3, how far from the center of the record can the coin be placed without having it slip off?
I'm plain lost on this one.
:frown:
Unless it's a roundoff problem, I don't see anything wrong. I did it a different way and got 0.0455 rev/ s.
[/quote]A coin is placed on a record that is rotating at 33.3 rpm. If the coefficient of static friction between the coin and the record is 0.3, how far from the center of the record can the coin be placed without having it slip off?
I'm plain lost on this one.[/QUOTE]
Let r be the distance from the center of the record to the coin. Then the acceleration of the coin is r(66.6π)2 so the force necessary to keep it rotating without slipping is rm(66.6π)2 (m is the mass of the coin). The maximum force the record can exert is 0.3 times the weight of the coin: 0.3(9.81)m= 2.943m. Set those equal and solve for r.
  • · Replies 51 ·
9K
