Relative velocity of a plane question
To calculate the velocity the pilot must maintain to reach her destination with a 25 m/s wind from the west, the initial velocity of the plane is 150 m/s at a bearing of N35E. The participant determined the east-west component of the plane's velocity to be 122 m/s east. By drawing a vector triangle and applying the cosine law, they found the resultant ground velocity to be 165.6 m/s at an angle of N42E. This method effectively combines the aircraft's velocity and wind speed to ensure timely arrival. The discussion emphasizes the importance of vector analysis in solving relative velocity problems.
mousemouse123
an aircraft must fly at a velocity of 150m/s[n35e] if there were no wind to reach its destination. a wind from the west of 25m/s is present for the whole flight. calculate the velocity the pilot must maintain to reach her destination in time. i started by finding the velocity of the plane in the east west dimenson. and got 122m/s [e] would i just add this number to 25 to get the right answer?
hi mousemouse123! :smile:
you need to draw a vector triangle …
what does it look like? :wink:
gee thanks... i drew a vector triangle already... that's how i got the velocity in the east west direction...
I found that the velocity of the plane to the ground was 165.6m/s (N42E).
I did this using the vector diagram then the cosine law to find the velocity of the plane to the ground, then the sine law to find the angle it travels. :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
