Why Does a Rock Stay on a Table?
  • Thread starter Thread starter Dooga Blackrazor
    Physics
The discussion revolves around the question of why a rock remains stationary on a table, exploring concepts related to gravity, molecular bonds, and forces at play. The original poster expresses curiosity about the theoretical implications of time on this scenario, particularly whether a rock could eventually penetrate the table or if the table would collapse under the rock's weight.
  • Participants discuss the role of gravitational force and molecular bonds in maintaining the rock's position. Questions are raised about the effects of time on the integrity of the table and the potential for chemical changes to alter the situation.
Some participants have offered insights into the forces involved, including gravitational and repulsive forces at the molecular level. There is an exploration of the conditions under which the rock might penetrate the table, though no consensus has been reached on the theoretical outcomes.
The original poster requests explanations using basic physics terms, indicating a focus on Newton's laws and a preference for accessible language in the discussion.
Dooga Blackrazor
My teacher was explaining why a rock sits on a table and doesn't move because of gravity. Apparently the surface area and thickness prevents the rock from going any further downward.
I asked my physics teacher if over time the rock would go through the table. He said probably not. I'm curious if an infinite time was used would the rock (theoritically(sp)) go through the table? Or would a table (in theory) eventually automatically collapse?
If not, I'm curious why.
If basic physics terms could be used it would be appreciated. I'm only on Newton's laws.
The reason has more to do with Chemistry than Physics (of course, the Chemistry involved has more to do with Physics than Chemistry, so...)
The force pulling the rock towards the center of the Earth isn't strong enough to break the bonds holding the molecules in the table together. The force definitely won't be strong enough to break the bonds in both the rock and the table (i.e. - you're not going to see the rock sink through the table). If it's a very heavy rock, you might 'snap' the bonds along an uneven line (i.e. break the table in half), but you'd almost certainly see some evidence right away (the table sagging, etc.).
Your gravitational force should stay pretty constant. An organic substance, such as wood, may undergo some chemical change that changes its strength, in which case the rock might eventually go through the table (the wood might rot, for example). Even a metal table could undergo some chemical change (rust, for example). The table's going to have to have some sort of chemical change occur that weakens the bonds among its molecules for the rock to eventually 'go through' the table.
I've got it. Thanks :)
Dear Dooga,
The Gravitational Force Keeps The Rock Down, But The Electrons Of The Rock And Of The Table Repel.
Therefore There Is A Balance Of Forces Involved, Which Causes The Rock To Stay Still.
Regards,
Roger
  • · Replies 24 ·
