Proving the Existence of Three Non-Collinear Points in an Affine Plane
  • Thread starter Thread starter gbean
The discussion focuses on proving that in an affine plane A = (P, L, I), the set of points P contains three distinct points that do not lie on a single line. The proof utilizes axioms AP1, AP3, and AP4, establishing that two lines, l and m, must either be parallel or intersect. In both cases, it is demonstrated that at least one point can be selected from a line distinct from the line containing two other points, thereby confirming the existence of three non-collinear points.
  • Understanding of affine planes and their properties
  • Familiarity with geometric axioms, specifically AP1, AP3, and AP4
  • Knowledge of rigorous proof techniques in geometry
  • Ability to analyze cases in mathematical proofs
  • Study the properties of affine planes in depth
  • Learn about different types of geometric proofs and their structures
  • Explore the implications of parallel and intersecting lines in geometry
  • Practice constructing rigorous proofs using axiomatic systems
Students of geometry, mathematicians focusing on affine geometry, and anyone interested in understanding the foundations of geometric proofs.
gbean
Affine Plane--Geometry
A = (P, L, I) is an affine plane. Prove that P (the set of all points) contains 3 distinct points that do not lie on a line.
Can only use the following:
AP1: For any two distinct points P & Q, there exists one unique line incident (crosses through) with P and Q.
AP3: Each line is incident (crosses through) with at least 2 points.
AP4: There exist at least 2 lines.
I'm having a lot of trouble writing rigorous proofs, so any help would be appreciated.
I used AP4 to say that there exist two lines, called l and m.
There are now two possible cases.
i) Either l is parallel/disjoint to m,
ii) or l intersects with m.
By AP3, each line l and m is incident (passes through) at least 2 points. l = L1L2, where L1 and L2 are points, and m = M1M2.
In case i), it isn't possible to draw a squiqqly sort of line that goes through any 3 points by AP1, which states that for any two distinct points, there is only 1 line that is incident with both points. So it is not possible to have 3 points on 1 line.
In case ii), define the intersection of l and m as a point n. Again, by AP1, for any 2 distinct points, there is only 1 line that is incident with both points. By this, there are 2 lines that contain 3 points.
I feel like I did not rigorously prove this, or that I am missing a few cases. Please help!
AP4 says that there exist at least 2 distinct lines, call them l1 and l2. Take, as part of your set of three points the two points that you know, by AP3, lie on l1. Since l2 is a different line from l1, there exist at least one point on l2 that is not on l1. Take that point as the third point in your set.
Would that be the entirety of a rigorous proof? Thank you very much for your help, I'm still trying to get the hang of this.
  • · Replies 36 ·
