Java Graphics & 2D Help me animate this
  • Context: Comp Sci
  • Thread starter Thread starter iamjon.smith
    2d Graphics Java
This discussion focuses on animating a neon sign logo using Java's Graphics and Graphics2D libraries. The user, Jonathan Smith, seeks guidance on implementing a flashing effect for his logo, which includes text and shapes. The recommended approach involves using the Thread.sleep() method to create a delay between drawing the "on" and "off" states of the logo. The provided code demonstrates the setup of the logo, but lacks the animation logic, which is crucial for achieving the desired effect.
  • Java programming fundamentals
  • Understanding of Java Swing for GUI applications
  • Familiarity with Graphics and Graphics2D classes
  • Basic knowledge of threading in Java
  • Implement animation logic using Thread.sleep() in the paint method
  • Explore Java Swing Timer for smoother animations
  • Research double buffering techniques to reduce flickering during redraws
  • Learn about the Java AWT Event Dispatch Thread for managing GUI updates
Java developers, graphic designers, and anyone interested in creating animated graphics within Java applications.
iamjon.smith
Java Graphics & 2D Help me animate this!
Instructions :
Using Graphics and Graphics2D, create a neon sign for your business logo. Create your logo to include a shape and the name of your business. The logo should flash off and on continuously. You may get as creative as you wish with your logo.
Investigate using a delay to draw and then redraw your logo so that it behaves like a neon sign.
So far I have created the graphic and just need to animate it. My Instructor has recommended using a delay to draw and redraw, but I can't figure out how to use delay. I just need someone to point me in the right direction once again.
Here is my code:
The Frame Class:
Code:
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.geom.GeneralPath;
import javax.swing.JPanel;
import java.awt.Color;
import java.awt.Font;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
 * @author Jonathan Smith
public class ColorFrame extends JPanel{
    @Override
    public void paint( Graphics g){
        super.paintComponent( g ); // call superclass's paintComponent
        Graphics2D g2d = (Graphics2D)g;
        this.setBackground( Color.BLACK );  // set background color of frame
        g.setFont( new Font("Comic Sans", Font.BOLD, 20)); // Set Font attributes
        g.setColor(Color.YELLOW);   // Set Font color
        g.drawString("CODE TALKERS INC.",70, 50 ); // Draw text, set position
        g.setColor(Color.YELLOW);  // Set color of rounded rectangle around text
	g.drawRoundRect(65,27,210,30,25,25);    // Draw rounded rectangle around text
        g.setColor(Color.YELLOW);   // set color of shape
        g.fillArc(20, 50, 30, 30, 0, -320); // draw shape
        g.setColor(Color.BLACK); // set color shape for eye
        g.fillArc(30, 55, 5, 5, 0, -360); // draw round eye
        g2d.setColor(Color.YELLOW); // set color for first line of speech bubble
        g2d.drawLine(55, 58, 74, 57); // draw first line of speech bubble
        g2d.setColor(Color.YELLOW); // set color for second line of speech bubble
        g2d.drawLine(55, 58, 65, 48);   // draw second line of speech bubble
        g2d.setColor(Color.BLACK); // set color of circle to black out corner of rounded rectangle
        g2d.fillArc( 65, 45, 5, 10, 0, -360); // draw circle to black out corner of rounded rectangle
        g2d.setColor(Color.BLACK); // set color of second circle to finish corner black out
        g2d.fillArc( 68, 50, 11, 7, 0, -360); // draw second circle to finish corner black out
and my main class where the frame class is called:
Code:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
import java.awt.*;
public class CompanyLogo {
     * @param args the command line arguments
    public static void main(String[] args) {
        // create frame for ColorFrame
        JFrame frame = new JFrame("Code Walkers Inc.");
        frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        ColorFrame colorFrame = new ColorFrame();   // create ColorFrame
        frame.add( colorFrame );    // add colorFrame to frame
        frame.setSize( 400, 140 );  // set frame size
        frame.setVisible(true); // display the frame
    }// end main
}// end class CompanyLogo
I know there are some unused imports, and I will remove those once the project is finished. I am still learning the graphics side of java, so bear with me.
I would like for the "speech bubble" (comprised of 2 lines, a rounded rectangle, 2 circles to black out the corner of the rounded rectangle and the text) to flash on and off. Once I get the delay figured out I am considering redrawing the "Pac Man" to make it look like he is talking as well.
You could have a loop that draws the "on" version, then a delay, then the "off" version.
One way to accomplish a delay is to put the thread to sleep, using the static sleep() method of the Thread class.
In pseudo code, this would be
Code:
loop
   paint "on" image
   sleep
   pain "off" image
   sleep
end loop
The call to sleep looks like this:
Code:
Thread.sleep(2000);  // Pause thread for 2 seconds.
The sleep method is in java.lang.Thread.
13K
