Calculating Kinetic Energy & Velocity of Electrons/Protons
This discussion focuses on calculating the kinetic energy and velocity of electrons and protons accelerated through potential differences of 300V and 1MV. The kinetic energy (KE) for both particles at 300V is established as 300eV, equivalent to 4.8 x 10-17 J. The total energy is determined to be the sum of kinetic energy and rest mass energy, expressed as Etotal = KE + mc2. For the 1MV scenario, the relativistic equations are applied for the electron, yielding a velocity of 2.8228 x 108 m/s, while the classical equation is used for the proton, resulting in a velocity of 1.384 x 107 m/s.
  • Understanding of kinetic energy calculations using KE = (1/2)mv2
  • Familiarity with relativistic equations, specifically KE = (mc2)/(sqrt(1-(v/c)2)) - mc2
  • Knowledge of potential energy in electric fields, W = qdV
  • Basic principles of special relativity and its implications on particle velocities
  • Explore the derivation and application of relativistic kinetic energy equations
  • Learn about the implications of potential energy in electric fields for charged particles
  • Investigate the threshold velocities for using classical versus relativistic mechanics
  • Study the effects of high-energy particle accelerators on electron and proton behavior
Students in physics, particularly those studying electromagnetism and particle dynamics, as well as educators seeking to clarify concepts of kinetic energy and relativistic effects in particle acceleration.
reality99
Electrons are allowed to be accelerated through a 300V potential difference.
a) Determine the electron's kinetic energy, total energy, and velocity.
b) Repeat for a proton instead of electron
c) Assume a potential difference of 1MV instead of 300V, repeat the above calculations
W=qdV
KE=(1/2)mv^2
KE=(mc^2)/(sqrt(1-(v/c)^2))-mc^2
It's been 2 years since a quantum mechanics course or physics course for that matter so bare with me if I missed something obvious.
(Part A&B)
KE is the same for both the electron and proton, 300eV
This translates to 4.8*10^-17J (from 1eV=1.6*10^-19J)
***What is the total energy?? I know it is PE+KE+U, but I can't remember how to find PE for electrons or protons. As the proton or electron is accelerated through the 300V, the KE gained=PE lost, correct? If so does that mean my total energy=2*KE or just KE?
I then used this and the mass of electron/proton to find V.
I calculated, for electron V=1.0271*10^7m/s, and for proton V=2.398*10^5m/s (from classical expression) what is the "threshold" where you must use relativistic equation? I know v<<c uses classical but what is considered much greater than c?
(Part C)
KE=10^6eV=1.6*10^-13J from same method as above.
Here I had to use relativistic equation for electron to find V=2.8228*10^8m/s, but used classical eq for proton and V=1.384*10^7m/s.
Is this the correct use of classical vs. relativistic equation?
If you made it to the end, thanks so much in advanced for the help!
'Looks good. :approve:
Don't overthink it. :-p. Yeah, the particles do have potential energy from the electric field before they are accelerated. But after the acceleration, that potential energy (from the electric field) gets converted to the particles' kinetic energy. So, sure, there's conservation of energy in that respect. But don't dwell on it. I'm pretty sure that you're not supposed to consider it quite that way (but you could if you really had to).
When the question asks for "total" energy, you can usually assume it's asking for KE + Mass energy. In other words,
Etotal = KE + mc2.​
It's possible that the question is asking for some other form of potential energy, but when involving special relativity, usually not. Regarding this problem, after the particle has been accelerated there are no other forms of potential energy anyway, so it's clear that the total energy is just the KE + mc2.
'Looks reasonable. :approve:
Oooh. That's a loaded question. :rolleyes:
The truth is you should ask your instructor. Later in life, when you don't have an instructor, it depends on how precise you want to be.
I've heard some specify that if the velocities involved are less than 0.2c, you're okay using the classical equations. But if you're looking for precise numbers, you might want to lower that to 0.1c.
In terms of kinetic energies, energy is proportional to the velocity squared, using classical equations. So if you have a velocity threshold of 0.1c before switching to relativistic equations, the kinetic energy threshold should be around 0.01c2. So if the kinetic energy involved is less than two orders of magnitude compared to the rest mass energy of the particle involved, you're probably okay sticking with classical equations. If the kinetic energy is greater than two orders of magnitude below the rest mass energy, and you might consider moving to the relativistic equations.
(Part C)
'Looks reasonable to me. :approve:
I think it's fine. But in truth it depends on how much precision you want or need. Try finding the proton's velocity in the 1 MV potential, using the relativistic equations. You'll find that your answer is quite close to what you found using the classical equations. But is it close enough? That's an answer for your and your instructor to decide. :wink:
  • · Replies 54 ·
12K
  • · Replies 44 ·
