Four-Momenta derivation: is this mathematical step even valid?
The discussion revolves around the mathematical validity of a step in the derivation of four-momenta in the context of Compton Scattering. Participants are examining the implications of squaring four-vector equations and the conservation of momentum in relativistic physics.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to clarify whether it is valid to square both sides of a four-momentum equation after rearranging terms. Some participants question the necessity of squaring first to maintain Lorentz invariance.
Participants are actively exploring the implications of squaring four-vectors and discussing the mathematical properties of four-momentum. There is recognition of the need for consistency in units and the potential loss of information when squaring equations. No consensus has been reached regarding the validity of the tutor's approach.
There are discussions about the assumptions related to the invariance of four-vector products and the need for clarity on given variables and unknowns in the problem setup.
whyamihere
Hey all, this is my first post to the forum, but I've been reading for years. Anyways, I was reviewing a solution to a Compton Scattering derivation we learned in class, and am still trying to make sense out of it.
Given, we have the initial and final four-vectors of the photon and electron:
Pphoton,i = (Ei, Ei ni)
Pphoton,f = (Ef, Ef nf)
Pelectron,i = (me, 0)
Pelectron,f = (gamma me, gamma mevi)
Using conservation of momentum, we get this expression:
Pphoton,i + Pelectron,i = Pphoton,f + Pelectron,f
This is where I get confused. Our tutor solved for the final electron term and then squared both sides like so:
|Pelectron,i|2 = |Pphoton,f + Pelectron,f - Pphoton,i|2
Is this action legal? Don't you have to square them first, then solve for the final electron term? Please, someone help clarify this. Everyone I ask seems to not even think twice about it. Is it really just a trivial step?
If you first square, you get
|Pphoton,i + Pelectron,i|² = |Pphoton,f + Pelectron,f
How are you going to get |Pelectron,f|² from that?
(Note that |a + b|² = |a|² + |b|² + (some very unpleasant cross terms) )
Thanks CompuChip.
Yes, that makes sense mathematically. It's the physics that I still am not getting. What is the reason for squaring both sides? Does that give us the square of the rest mass?
Actually, now I am convinced that I am right and my tutor made a mistake.
In order for this to be Lorentz invariant, the threshold energy s = |Pphoton,i + Pelectron,i|² = |Pphoton,f + Pelectron,f
So we MUST square each side first, otherwise it is not invariant.
Can anyone verify/refute this?
The square of any four-vector is an invariant, and more generally, the product of any two four-vectors is an invariant.
That really clarifies everything. Thanks vela!
You will want the units of photons and electons to match. For n unitless, and all vector components in units of energy:
Pelectron,i = (mec2, 0)
Pelectron,f = (γmec2, γmecvf)
Squaring things loses information.
Isn't Pphoton,i + Pelectron,i = Pphoton,f + Pelectron,f
four linear equations in four unknowns, γ and γvf?
However, you haven't actually stated what your givens and unknowns are.
It's common to use units where c=1 and drop the explicit factors of c from expressions. For example
[tex](mc^2)^2 = E^2 - (pc)^2[/tex]
becomes
[tex]m^2 = E^2 - p^2[/tex].
Sometimes you don't care about that information. :wink: A common trick in relativity calculations is to arrange the four-vectors so that a well-placed 0 will wipe out terms you don't really care about when you square the equation.
  • · Replies 24 ·
