Conducting Sphere shielding an electric field
The discussion revolves around the behavior of electric fields in relation to a hollow conducting sphere containing charges both inside and outside. Participants explore the implications of Gauss's Law and the mechanisms of charge redistribution on the sphere's surface, particularly focusing on the concept of shielding and the conditions under which external charges influence the electric field within the sphere.
  • One participant questions the traditional explanation that only the charges inside the conducting sphere affect the electric field within, suggesting that external charges may also play a role.
  • Another participant proposes that the redistribution of charge on the conducting sphere due to an external charge results in a net electric field of zero within the sphere.
  • It is mentioned that the field induced by the rearrangement of charge on the sphere's surface cancels out the field from the external charge, leading to no net field inside.
  • Analytical approaches using Stokes' Theorem and the Divergence Theorem are suggested to demonstrate the behavior of the electric field mathematically.
  • Concerns are raised regarding the application of the Divergence Theorem in non-conducting scenarios, indicating that external charges would affect the field within a non-conducting sphere.
  • Participants express interest in the properties of conductors, noting that a net electric field cannot exist on a conducting surface without causing a voltage.
Participants express differing views on the influence of external charges on the electric field within the conducting sphere. While some agree on the shielding effect described by Gauss's Law, others raise questions about the underlying mechanisms and the implications for non-conducting materials. The discussion remains unresolved regarding the complete understanding of these concepts.
Participants note limitations in applying mathematical theorems to different scenarios, particularly distinguishing between conducting and non-conducting materials. There is also a recognition of the complexity involved in understanding the mechanisms of charge redistribution and its effects on electric fields.
wil3
Conducting Sphere "shielding" an electric field
Hello. I have a question regarding a problem that I have seen printed many times in various books and which I saw on a test today:
A hollow conducting sphere contains 2 charges, [tex]q_1\;and\;q_2[/tex]. Outside the sphere are two additional charges, [tex]q_3\;and\;q_4[/tex]. Which charges determine the properties of the field within the sphere?
The answer, as is often printed, is that just the first two charges contribute to the field.
The traditional explanation of this answer involves Gauss's Law-- only the first two charges are enclosed within the conducting sphere, and so the divergence of the field there thus only relies upon those two sources.
After reflection, I recently realized that this cannot possibly be correct, since equal-field Gaussian surfaces can be arbitrarily produced.
What is the real reason for this? I would prefer a more intuitive, qualitative reason, although math is pretty cool too. I'm guessing that the specific way in which [tex]q_3\;and\;q_4[/tex] redistribute the charge on the conducting sphere somehow results in a null field within, but I can't for the life of me figure out how the fact that the sphere is conducting allows for shielding.
Thanks in advance
NVM, guys, I figured it out. I'll post it here for the sake of people who later find this thread:
Okay, so let's say I have one really big charge +Q acting on a conducting sphere- because the sphere *conducts* it will push all the positive charge away to the far side of the sphere. Let's think about the sphere now- all the positive charge has been pushed to one side, and all the negative charge stayed put. Thus there's a net electric field within the sphere, induced for the nearby charge.
But hey look! The field induced by the rearrangement of charge on the shell of the sphere is pointing in the OPPOSITE direction as the field due to the original charge, but we still have to include that original +Q field (ignoring the sphere) which we add to the secondary field that is the result of charge rearrangement on the sphere surface.
It just so happens that the vectors sum to zero everywhere within the aegis of the sphere. This is why Gauss's law is able to solve the problem; we can treat the interior as an isolated system electrically, since the field within is the same regardless of whether there is charge outside or not. If there is charge outside, it induces a field within the sphere that cancels itself out.
You can also show this analytically using the mathematical description of the electric field along with Stokes' Theorem.
As username Curl, I feel like I shouldn't be surprised that you recommend Stokes' Theorem.
How would I go about doing this? I know that the curl is zero everywhere because of conservative field properties, etc, etc.
I'm sorry, I meant the divergence theorem.
Write a vector field that represents the E field due to a point charge at the origin. Enclose it with any closed, oriented surface (piecewise smooth, etc etc) and compute the net flux through the surface, and you'll see it is just equal to the charge enclosed.
From the divergence theorem, you will see that the volume integral is the same regardless of the surface since div E times the volume elements add up to a constant (maxwell's first equation).
Thus if the charge is outside, there is no overall flux through the surface.
Also I'll add for reference that since the surface is conducting, it must represent an constant-potential surface.
No, I totally agree that, by Gauss's law (and thus the Divergence theorem), the net flux through a closed surface which contains no sinks or sources of a conservative field (aka, satisfies the Laplace equation) must be zero.
My problem with this is that this didn't adequately show me that the field is zero, since the divergence theorem would confound the electric field with the differential area element (making it very difficult to solve for a function for the field, which would be necessary to answer this question.)
For example, if the sphere was non-conducting, blindly applying the divergence theorum would be errant- while the flux integral would come out to null over the closed surface, the field within would definitely be affected by the external charges. The question was more about the mechanism by which conductors shield.
Also, I didn't know that about conductors- It makes sense now that you mention it, but that's still very cool. After all, there cannot be a net field on a conducting surface, since that would cause a voltage by the basic Q=Ed relation. Thanks, Curl!
