Rotational kinematics problem im stuck on
The discussion focuses on solving a rotational kinematics problem involving a pendulum with a string length L and a bob of mass m. The tangential component of acceleration of the bob is calculated as g * sin(Theta), where g is the acceleration due to gravity and Theta is the angle to the vertical. The torque exerted about the pivot point is determined to be mgL * sin(Theta), derived from the moment of inertia I = mL^2. The relationship T = I * alpha confirms that both the torque and tangential acceleration equations yield consistent results.
  • Understanding of rotational kinematics
  • Familiarity with the concepts of torque and angular acceleration
  • Knowledge of the moment of inertia for a pendulum
  • Basic understanding of trigonometric functions in physics
  • Study the derivation of the moment of inertia for different shapes
  • Learn about the parallel axis theorem in rotational dynamics
  • Explore the relationship between linear and angular motion in physics
  • Investigate the effects of varying angles on pendulum motion
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to pendulum motion and torque.
rememberww2
rotational kinematics problem I am stuck on please help!
my problem says this:
-a pendulum consisting of a string of length L attached to a bob of mass m swings in a vertical plane. When the string is at an angle Theta to the vertical, A) what ist he tangential component of acceleration of the bob? B)what ist he torque exerted about the pivot point? C)show that T = I Alpha with At = Lalpha gives the same tangential acceleration as found in part A.
i really have no idea on how to start, I would think i would need the parallel axis theorem but I am not sure on how to get started.
A) The tangential component of acceleration of the bob is given by: a_t = L * alpha, where alpha is the angular acceleration of the pendulum.B) The torque exerted about the pivot point is given by: T = I*alpha, where I is the moment of inertia of the bob and alpha is the angular acceleration of the pendulum.C) To show that T = I*alpha gives the same tangential acceleration as found in part A, substitute the expression for alpha into the equation T = I*alpha and rearrange to get: T = I * (a_t/L)The above equation shows that the torque T is equivalent to the moment of inertia I multiplied by the tangential acceleration a_t divided by the pendulum length L.
Hi there,
I can understand how this problem may be challenging for you. Rotational kinematics can be a tricky topic, but with the right approach, you can definitely solve this problem.
First, let's break down the problem into smaller parts. We are dealing with a pendulum, which means that the bob is swinging back and forth in a circular motion. This motion can be described using rotational kinematics.
A) The tangential component of acceleration is the acceleration along the tangent of the circular path. In this case, it is the acceleration of the bob in the direction of its motion. To find this, you can use the equation a = rα, where a is the tangential acceleration, r is the radius of the circular motion (which is equal to the length of the string, L), and α is the angular acceleration. Since the bob is swinging in a vertical plane, the angle between the string and the vertical is Theta. This means that the angular acceleration can be expressed as α = g/L * sin(Theta). Substituting this into the equation, we get a = rα = L * (g/L * sin(Theta)) = g * sin(Theta). Therefore, the tangential component of acceleration is g * sin(Theta).
B) To find the torque exerted about the pivot point, you can use the equation τ = Iα, where τ is the torque, I is the moment of inertia, and α is the angular acceleration. The moment of inertia for a pendulum is given by I = mL^2, where m is the mass of the bob and L is the length of the string. Substituting this into the equation, we get τ = Iα = mL^2 * (g/L * sin(Theta)) = mgL * sin(Theta). Therefore, the torque exerted about the pivot point is mgL * sin(Theta).
C) Now, let's show that T = Iα with At = Lα gives the same tangential acceleration as found in part A. We know that T = Iα and At = Lα. Substituting the value of I from the previous equation, we get T = mL^2 * α and At = Lα. Since α = g/L * sin(Theta), we can write T = mgL * sin(Theta) and At = g * sin(Theta). As you can see, both equations give the same value for
  • · Replies 78 ·
11K
