Understanding Voltage: Why does Charge not Affect Voltage?
  • Context: High School
  • Thread starter Thread starter greeneyehawk
    Concept Voltage
The discussion revolves around the concept of voltage and its relationship with electric charge, particularly why voltage does not seem to depend on the type of charged particle (electron vs. proton) moving through an electric field. Participants explore the nature of electric fields, potential difference, and the implications of moving charges.
  • One participant questions why voltage is the same for electrons and protons moving in the same direction, suggesting a misunderstanding of potential difference.
  • Another participant asserts that the effects of electrons and protons are opposite due to their charges, implying that their contributions to voltage differ.
  • A participant proposes that visualizing the electric field differently may clarify the relationship between charge movement and potential difference.
  • There is a discussion about the nature of electric fields, with one participant explaining that electric potential can exist independently of charged particles, referencing magnetic fields and their relation to electric fields.
  • Another participant challenges this view, citing Einstein's work on the interrelation of electric and magnetic fields, arguing that both are results of charge interactions and that the two are not merely different manifestations of the same phenomenon.
  • Some participants draw analogies between electric potential and gravitational potential, suggesting that moving against the electric field increases potential, similar to climbing a hill increasing gravitational potential.
Participants express differing views on the relationship between electric and magnetic fields, with some supporting the idea that they are fundamentally linked while others argue against this perspective. The discussion remains unresolved regarding the nature of voltage and its dependence on charge.
Participants reference various concepts from physics, including the behavior of charges in electric fields and the implications of Einstein's theories, indicating a reliance on specific definitions and interpretations that may not be universally accepted.
greeneyehawk
Hi, I have been having trouble understanding this: Potential difference(Voltage) increases when charged particles travel against electric field lines.
My question is why does the charge of the particle not affect Voltage? Why does an electron and a proton traveling in the same direction cause the same Voltage?
They don't. Their effects are opposite as you would expect from opposite charges.
Maybe I'm asking this wrong. I want to know why there is higher potential against electric field lines and lower potential with electric field lines.
Visualize the electric field a different way and I think your understanding will clear up.
Electric field is nothing more then the tendency of like electrostatic charges to repel one another and unlike charges to attract. If you have a positively charged object and a negatively charged object the excess protons in the positively charged object will repel each other. Electrons in the negatively charged object will also try to repel each other. Electrons in the negatively charged object will be attracted to protons in the positively charged object and vice verse. This attraction is measured in volts. This attraction (voltage) causes electrons to move from the negative object to the positive object, it is also possible for protons to move from the positive object to the negative object. That would not happen very much in a solid medium but in a liquid, gaseous, or plasma medium it certainly can. The movement of the charges is called current and measured in amperes.
The idea that electric potential can exist independent of charged particles comes from the idea that voltage can be induced my a magnetic field in an otherwise neutrally charged object. This idea becomes unnecessary if magnetic fields are understood as nothing more then the result of electric fields that are in motion with respect to one another. Here is a link that explains this concept very well...
http://physics.weber.edu/schroeder/mrr/MRRtalk.html
So with this bit of understanding magnetism is out the window and everything is understood as the interaction of charged particles. To my mind this is the simplest possible explanation. Everything is nice and tidy and self consistent. That's how I like it. :-)
When you run up a hill (ie. against the gravitational field) do you increase or decrease your gravitational potential?
AM
AM
increase
This helps, thanks!
greeneyehawk said:
increase
Similarly, when you push a charge against the electric force, you increase its potential. The only difference is that gravity is always attractive whereas an electric force can be attractive or repulsive. An electric field, by convention, points in the direction that a free positive charge will move. So a negative charge naturally moves against the direction of the electric field (we could have established a different convention but it was set before anyone understood what charge was). So for a negative charge you have to do work when moving in the direction of electric field (ie. against the force on the negative charge) in order to increase its potential.
AM
I don't think that is what modern physics says. Magnetic fields are due to charges in motion. According to A Einstein in his 1905 paper "On The Electrodynamics Of Moving Bodies", between electric & magnetic fields, that neither is the seat. The two are interrelated & it is safe to say that charges give rise to both E & H fields. But to say that magnetic is just a moving version of electric, goes counter to relativity & QED. Both E & H (or "B" if you prefer) are a result of charge interaction. Static charges result in E, whereas moving charges produce H. Different reference frames see differing proportions of E & H, but the two are inclusive, neither being more fundamental.
I don't wish to notpick, but Einstein's 1905 paper still stands in the science community today. No discovery has been made to void said position. E & H are 2 sides of the same coin.
Claude
Claude
I'm not disputing that. Any mathematical model that makes correct predictions can be thought of as correct. Einsteins model meets that criteria and so it is a good model. Modeling everything as E fields as outlined in the link I provided makes identical predictions and so is an equally valid model. Whichever model you find more intuitive or easier to use is the one you should use.
  • · Replies 21 ·
