| New Reply |
[Chemistry] Trying to find the vapor pressure of water with pv=nRT |
Share Thread | Thread Tools |
| Jan30-11, 12:03 PM | #1 |
A student found that at 750 torr atmospheric pressure and 0.1 deg C, the corrected volume of the trapped air (in a graduated cylinder filled with water inverted in beaker) was 2.20 mL. Under these conditions, how many moles of trapped air are present? This student then heated the beaker and found that at 70 deg C, the corrected volume of the bubble was 4.05 mL. What should she report as the vappor pressure of water at this temperature? My problem is that I am finding that pressure air, from the first part, exceed pressure total, from the second part. 2. Relevant equations PV=nRT (ideal gas law) R=0.082L*atm/K*mol 3. The attempt at a solution Part 1: PV=nRT. 2.20 mL=0.0022 L. R as above. 750 torr=0.987 atm. 0.1 deg C=273.3K 0.987 atm*0.0022L = n moles*(0.082L*atm/(K*mol))*273.3K solve for n. n=1*10^(-4) moles. Part 2: PV=nRT. P_air=0.987 atm. 4.05mL=0.00405 L. n=1*10^(-4) moles. P*0.00405L=0.0001 moles*0.082(L*atm/K*mol)*343.15K Solve for P: P_total=0.7 atm. How can P_total be less than P_air? I should be able to get the partial pressure of the water vapor at 70 deg C from this, but that would come out negative. Any help would be greatly appreciated. |
| Jan30-11, 01:58 PM | #2 |
Admin
What you have calculated is the pressure of air, not total pressure. Total is still 750 torr.
Don't round down intermediate results - that is, list them as rounded, but use them in calculations with full accuracy. |
| New Reply |
| Thread Tools | |
Similar Threads for: [Chemistry] Trying to find the vapor pressure of water with pv=nRT
| How do I get water vapor fraction and pressure? | General Engineering | 2 | ||
| Vapor Pressure of Water | Biology, Chemistry & Other Homework | 2 | ||
| Increasing vapor pressure in water | Chemistry | 1 | ||
| Chemistry - vapor pressure | Biology, Chemistry & Other Homework | 3 | ||
| Vapor pressure of Water calculation | Biology, Chemistry & Other Homework | 3 | ||
