Solve Highest/Lowest Points on Curve of Intersection with Lagrange Multipliers
The discussion focuses on using Lagrange multipliers to determine the highest and lowest points on the curve of intersection between an elliptic paraboloid defined by the equation z = x^2 + 2*x + 4*y^2 and a right circular cylinder described by x^2 + y^2 = 1. The critical points identified are (2/3, -√5/3) and (-√2/6, 1). Participants clarified the correct formulation of the elliptic paraboloid, confirming it as z = x^2 + 2*x + 4*y^2.
  • Understanding of Lagrange multipliers
  • Familiarity with elliptic paraboloids
  • Knowledge of right circular cylinders
  • Basic calculus concepts, particularly optimization techniques
  • Study the method of Lagrange multipliers in depth
  • Explore the geometric interpretation of critical points on surfaces
  • Learn about second derivative tests for optimization
  • Investigate the properties of elliptic paraboloids and their applications
Students and professionals in mathematics, particularly those studying multivariable calculus, optimization techniques, and geometric analysis of surfaces.
Cherizzle
Hi There I would like help on a question about Lagrange multipliers.
Question: Consider the intersection of two surfaces: an elliptic paraboloid z=x^2 + 2*x + 4*y^2 and a right circular cylinder x^2 + y^2 = 1. Use Lagrange multipliers to find the highest and lowest points on the curve of the intersection.
What I have so far:
I managed to find my critical points using lagrange multipliers. But now I don't know how to describe whether my points are at maximum or minimum...
The points I found were: (2/3, -[tex]\sqrt{5}[/tex]/3) and (-[tex]\sqrt{2}[/tex]/6, 1)
Hi Cherizzle. Are you sure that's supposed to be z=x^2 + 2*x + 4*y^2 and not z=x^2 + 2*x*y + 4*y^2
