Convergent Integral Solution | Determining Convergence with f(x) and g(x)
The integral \(\int_{0}^{\infty}\frac{dx}{1+(x\sin x)^{2}}\) does not converge. The discussion highlights an attempt to establish convergence using a comparison function \(g(x)\), defined piecewise, but ultimately concludes that the approach is flawed. The correct method involves rewriting the integral as a sum of integrals over intervals of length \(\pi\) and applying appropriate bounds to analyze convergence. The integral diverges due to the behavior of the sine function and the growth of \(x\).
  • Understanding of improper integrals and convergence criteria
  • Familiarity with trigonometric functions, particularly \(\sin x\)
  • Knowledge of comparison tests for integrals
  • Ability to manipulate and transform integrals using substitution techniques
  • Study the comparison test for improper integrals
  • Learn about convergence of integrals involving trigonometric functions
  • Explore techniques for bounding integrals, particularly with periodic functions
  • Investigate the behavior of \(\sin x\) and its implications on integral convergence
Students and educators in calculus, mathematicians analyzing convergence of integrals, and anyone studying advanced integration techniques.
talolard
Does [tex]\int_{0}^{\infty}\frac{dx}{1+\left(xsinx\right)^{2}}[/tex] converge?
I don't know if this is a legitimate solution. Any insight? Thanks
Tal
No.
[tex] f(x)=\frac{1}{1+\left(xsinx\right)^{2}}\geq g(x)=\begin{cases}<br /> \frac{1}{1+\left(xsin(x)\right)^{2}} & 2\pi k\leq x\leq2\pi k+\pi\\<br /> 0 & \else\end{cases}[/tex]
Then [tex]\int_{0}^{\infty}\frac{dx}{1+\left(xsinx\right)^{2}}\geq\int_{0}^{\infty}g(x)=\sum_{k=0}\int_{2\pi k}^{2\pi k+\pi}\frac{1}{1+\left(xsin(x)\right)^{2}}\geq\sum_{k=0}\int_{2\pi k}^{2\pi k+\pi}\frac{1}{1+\left(\frac{\pi}{2}\right)^{2}}=\sum_{k=0}^{\infty}\frac{\pi}{1+\left(\frac{\pi}{2}\right)^{2}}[/tex]
talolard said:
[tex]\sum_{k=0}\int_{2\pi k}^{2\pi k+\pi}\frac{1}{1+\left(xsin(x)\right)^{2}}\geq\sum_{k=0}\int_{2\pi k}^{2\pi k+\pi}\frac{1}{1+\left(\frac{\pi}{2}\right)^{2}}[/tex]
I don't see why that step should be true, since [itex]\pi/2[/itex] doesn't bound x sin x. This attempted solution was incorrect unfortunately although you are correct in that it does not converge.
To start the problem, write down [tex]\int^{\infty}_0 \frac{1}{1+x^2 \sin^2 x} dx = \sum_{k=0}^{\infty} \int^{(k+1)\pi}_{k\pi} \frac{1}{1+x^2 \sin^2 x} dx[/tex].
Then let [itex]x = u + k \pi[/itex] and try to bound the integral.
  • · Replies 47 ·
