Calculate the area of a sphere using an integral
The discussion revolves around calculating the surface area of a sphere using integral calculus, specifically through the function f(x) = √(1 - x²). Participants explore the method of slicing the sphere into cylinders and integrating to find the surface area, while questioning the validity of their approaches and assumptions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss slicing the sphere into cylinders and using integrals to calculate surface area. Questions arise regarding the accuracy of approximating the surface area with flat cylinders and the implications of using different radii for slices. There is also a debate about the correct application of the formula for surface area and the interpretation of the resulting integrals.
The discussion is ongoing, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the correct interpretation of the integral and the nature of the slices used in the approximation, but no consensus has been reached on the best approach.
Participants express confusion over the assumptions made in their calculations, particularly concerning the geometry of the slices and the application of the integral. There is also mention of potential discrepancies in the results when comparing calculated areas to expected values.
Mantaray
I tried to calculate the area of a sphere using the function [tex]f(x) = \sqrt{1-x^2}[/tex]
hmm?
So I thought I could slice up the sphere in small cylinders, and then calculate the outer surface by circumference * height of all the cylinders and then add them together.
In this case, the radius would be equal to f(x) and the height of the cylinder would equal [tex]\Delta x[/tex]. So the surface of the whole sphere would be:
2pi \int f(x) dx with lower limit -1 and upper limit 1. However, this does not seem to equal 4pi*r^2, I checked this with r = 1. It gives two quite distinct values.
Where did I go wrong?
hmm?
What sort of a knife could you use to slice a sphere into cylinders? When you slice something, you get flat surfaces along the cut.
The integral you arrived at is way off.
[tex]2\pi \int_{-1}^1 \sqrt{1 - x^2}dx[/tex]
The integral itself represents the area between the upper half circle of radius 1, centered at (0, 0). This area is [itex]\pi /2[/itex], so multiplying by [itex]2\pi[/itex] gives [itex]\pi ^2[/itex].
You started off with f(x) = sqrt(1 - x^2). If you revolve that curve around the y-axis, you get the upper half of a sphere of radius 1. You can slice this hemisphere into horizontal slices, and calculate the surface area of each slice, then integrate to get the surface area of the hemisphere. For the whole sphere, you'll need to double that result.
But won't you get really flat cylinders by approximation when you slice a hemisphere horizontally?
So using the formula S = 2pi \int y sqrt(1 + f'(x)^2) dx I can calculate the surface area of a sphere segment. Thus dS = 2pi y sqrt(1 + f'(x)^2). This is the surface area of a cylinder with radius = y and height = sqrt(1 + f'(x)^2), which is the change in the length of the arc for a small change in x. Does this formula not still use really flat cylinders to approximate the surface area of the sphere?
I tried the above formula on the graph of y = ax:
S = 2pi \int y sqrt(1 + a^2) dx
and
dS = 2pi y sqrt(1 + a^2)
What bothers me is that when x is increased by a very small amount, the increase in surface area is given as the surface area of a cylinder with radius y and height sqrt(1 + a^2), but the actual increase in surface area does not correspond with this at all because for a small increase in x a cone segment is added at the bottom of the cone and not a really flat cylinder. The difference in surface area of the cone segment and the cylinder becomes smaller as the increase in x becomes smaller (does this difference approach 0?), but this is counter-intuitive, as a staircase-like shape is used to approximate a straight line?
Thanks for the help = )
None of the slices will be cylinders, since the top and bottom radii are different for each slice. Of course, the lower on the hemisphere the slice is, the closer the slice is to being a cylinder.
No, that's not quite right. You have y for the radius - it should be x.
See above. Also, you're missing the differential on the right side.
It effectively uses thin slices of a cone. That's where the sqrt(1 + (f'(x))^2)dx part comes in.
and
But I revolved around the x-axis there, so the radius should be y?
The pdf file should be easier readable for you, if you don't mind.
