Calculating Average of Quantities with Different Values - Step-by-Step Guide
  • Context: High School
  • Thread starter Thread starter atomqwerty
The discussion revolves around calculating the average of a set of quantities that have different associated values, specifically focusing on the concept of weighted averages. Participants explore the method of incorporating weights into the average calculation, particularly in the context of academic grades associated with different hours of study.
  • One participant expresses confusion about calculating an average when quantities have different values and questions the method used for averaging.
  • Another participant clarifies that the values represent the importance of each quantity rather than their frequency, relating it to calculating a grade point average based on hours of study.
  • A suggestion is made that the participant is looking for a "weighted" average, providing a formula for calculating it based on the weights of the values.
  • Examples are provided to illustrate how to compute a weighted average using both numerical values and associated weights.
Participants generally agree on the concept of using a weighted average to solve the problem, although there is some initial confusion about the terminology and method of calculation.
The discussion includes assumptions about the definitions of weights and values, and the specific context of academic grading is highlighted, which may not apply universally to all averaging scenarios.
Individuals interested in statistical methods, particularly in educational contexts, or those looking to understand how to calculate averages when dealing with varying weights or values.
atomqwerty
Hi,
I want to determinate the average of a set of quantities which each one has a different value, for example
3 has value 4.5
4 has value 5
3.5 has value 6
4 has value 3
5 has value 5
and so on...
If I do 3*4.5 + 4*5 + 3.5*6 +... and divide it by the number of elements I obtain a number that is not the average of the set...
Any help for this noob?
Thanks!
If I replace "has" with "have" I think I understand what you are trying to do, right up to "3.5"... I just can't figure out how you have 1/2 of something with a specific value.
Can you explain the problem a bit more? And also how do you know what the average should be? Answers in back?
It's a way to measure the real average of a set, and where I write 4.5, it doesn't mean that the associated value appear 4 + 1/2 times, but it means the importance of that value. The problem itself is to calculate the grade point average, and I associate the puntuation with the hours of the subject, for example
Maths: 7.8 (45 hours)
Physics: 8.9 (60 hours)
I want to calculate the average keeping in mind that each subject has a determinate number of hours.
Saludos!
Sounds to me like you want a "weighted" average.
If you have value 4.5 with weight 3, 5 with weight 4, 6 with weight 3.5, 3 with weight 5, and 5 with weight 5, then the weighted average is
[tex]\frac{3(4.5)+ 5(5)+ 3.5(6)+ 5(3)+ 5(5)}{3+ 4+ 3.5+ 5+ 5}[/tex]
the sum of each value multiplied by its weight, divided by the sum of the weights.
Similarly, if you have a grade of 7.8 with a weight of 45 hours and a grade of 8.9 with a weight of 60 hours then the weighted average is
[tex]\frac{7.8(45)+ 8.9(60)}{45+ 60}[/tex]
Thanks, HallsofIvy and Schip666! for your help, very useful!
  • · Replies 41 ·
