How do u increase the sensitivity of an IR sensor?
To increase the sensitivity of an IR sensor, specifically an NPN IR photo-transistor, one effective method is to configure it in a Darlington arrangement with another sensitive NPN transistor. This setup involves creating a collector-base connection on the second NPN transistor, allowing it to activate when there is a potential across its collector-emitter junction. This configuration significantly enhances the sensor's responsiveness to infrared light.
  • NPN IR photo-transistor functionality
  • Understanding of Darlington pair configuration
  • Basic knowledge of transistor operation
  • Familiarity with collector-emitter junction behavior
  • Research Darlington pair applications in sensor technology
  • Explore advanced NPN transistor configurations
  • Study the impact of collector-emitter voltage on transistor sensitivity
  • Learn about alternative methods to enhance IR sensor performance
Electronics enthusiasts, sensor developers, and engineers looking to improve the sensitivity and performance of infrared sensors.
vivazza
how do u increase the sensitivity of an IR sensor? what are the options?
If you're talking about an NPN IR photo-transistor, use it in a darlington arrangement with another sensitive NPN transistor.
In other words, use it to make a collector-base connection on another NPN transistor. Then, if there's a potential across the second transistor's collector-emitter junction any IR on the phototransistor will "turn on" the NPN transistor.
  • · Replies 16 ·
  • · Replies 26 ·
9K
