What are the advantages of using an immersion heater at the top of a water tank?
The discussion highlights the advantages of using an immersion heater at the top of a water tank, particularly in scenarios where water is drawn from the top. It establishes that a two-element electric water heater, with a lower-temperature element set at the bottom and a higher-temperature element at the top, is more efficient. The lower element preheats the majority of the tank to approximately 110 degrees Fahrenheit, while the upper element heats the top third to 130 degrees Fahrenheit, minimizing energy waste during periods of low demand.
  • Understanding of two-element electric water heaters
  • Knowledge of water heating efficiency principles
  • Familiarity with temperature settings in heating systems
  • Basic concepts of heat loss in water tanks
  • Research energy efficiency in water heating systems
  • Learn about the design and operation of two-element water heaters
  • Explore methods to minimize heat loss in water tanks
  • Investigate alternative water heating technologies
Homeowners, HVAC professionals, and anyone interested in optimizing water heating efficiency in residential settings.
Janessa
Firstly there is no advantage except if you are drawing water from the top. Thats because if you are not drawing water from the top, then the water at the surface that is in direct contact with the immersion heater will evaporate! :shy:
If you are referring to a statndard electric water heater for a home, a two-element heater usually has a lower-temperature heater at the bottom and a higher watt-higher temperature set at the top. As maverick stated, water is usually drawn from the top.
THe lower element preheats most of the tank to, say 110 degrees, and the higher one will heat the upper third to 130 degrees. Overall this is more efficient since less energy will be wasted keeping all 80 gallons at the higher temperature while the whole family is sleeping (and heat radiates out of the heater).
  • · Replies 22 ·
  • · Replies 66 ·
