Q26: Electron Gun Physics - Kinetic Energy, Force, Acceleration & Time of Flight
The problem involves an electron gun in a television set, focusing on the acceleration of electrons through an electric field created by charged plates. Participants are tasked with determining the kinetic energy, force, acceleration, and time of flight of the electrons as they travel between the plates.
  • Participants discuss the kinetic energy formula, with one suggesting the use of 1/2 mv² for energy calculations. Others mention known values such as the mass of the electron and the final velocity as a fraction of the speed of light.
Some participants express confusion and seek hints on how to approach the problem. Guidance has been offered regarding the use of kinematic equations and the relationship between force, mass, and acceleration. There is an ongoing exploration of the calculations needed to find the required values.
Participants are working under constraints of a homework assignment, which may limit the information available to them. There is also a mention of potential typographical errors in the problem statement regarding the speed of the electrons.
Faiza
Q26. In the neck of the picture tube of a certain black-and-white television set, an electron gun contains two charged metallic plates 2.80 cm apart. An electric force accelerates each electron in the beam from rest to 9.60% of the speed of light over this distance. (a) Determine the kinetic energy of the electron as it leaves the electron gun. Electrons carry this energy to a phosphorescent material on the inner surface of the television screen, making it glow. For an electron passing between the plates in the electron gun, determine (b) the magnitude of the constant force acting on the electron, (c) the acceleration, and (d) the time of flight.
i need help i dun know what to do
im so lost on this supplementry problme and the text is of no help
can anyone give me some hints how to solve this porblem, because I am thinking the energy of the electron wud be 1/2mv^2
:'( ......im so lost
You know the mass of the electron...
Hence, you were right in thinking 1/2 mv2 is the energy of the electron and v = 0.96C where C is the speed of light...
Now you know the final velocity and the initial velocity of the electron and the distance it travels... come in Newton... equation of motion...
V2 - U2 = 2*Acc*Distance
Which will give you Acc...
Force = Mass * Acc... so there you go...
Proceed along those lines and you should be good...
its 9.60%=9.60/100=0.096c?? right I am sure that was juss a typo??
im going to try it
(a) 3.7*10^-16 Joules
(b)F=1.34*10^.14 Newtons
(c)a=1.48*10^16 m/s^2
(d) time of flight=1.94*10^6 seconds
please check my answers if u have time please
