DC to AC conversion and power relation
The discussion revolves around the conversion of DC to AC power, specifically focusing on how devices like the "AC Anywhere" inverter can convert 12 volts DC from a vehicle battery to 230 volts AC. Participants explore the implications of power draw, efficiency, and the limitations of using such inverters for various applications, including running motors of significant power ratings.
  • Some participants express curiosity about how a 12V DC supply can produce 230V AC, questioning the efficiency and power draw of such devices.
  • One participant explains that while the inverter can supply 150W at 230VAC, it draws approximately 15A at 12V, indicating a conversion efficiency of around 90%.
  • Another participant raises concerns about the power limitations of a battery when using an inverter, suggesting that a battery running for 6 hours at 12V could be drained quickly when drawing 230V.
  • There is discussion about the feasibility of running high-power devices, such as a 5 HP motor, on a 12V inverter, with one participant noting that the inverter must match the wattage requirements of the device.
  • Participants discuss the need for continuous charging of the car battery when using an inverter due to the heavy power drain.
  • One participant mentions the possibility of converting 230V AC back to 230V DC using a rectifier, while another suggests that for smaller voltage changes, DC-DC regulator circuits like Buck Converters could be used.
  • Clarifications are made regarding the distinction between voltage and power, with a formula provided to illustrate the relationship between voltage, current, and power, factoring in conversion efficiency.
  • One participant shares motor specifications and questions whether these motors can be run on a 12-24V DC inverter, seeking guidance on selecting an appropriate inverter based on power ratings.
  • Another participant argues that running a 3 HP motor off a 12V system is impractical due to the high current requirements, which exceed what a typical car battery can supply.
Participants generally agree on the limitations of using a 12V battery for high-power applications, but there are competing views on the specifics of inverter capabilities and the feasibility of running certain devices. The discussion remains unresolved regarding the practical application of inverters for high-power motors.
Participants highlight various assumptions, such as the efficiency of inverters and the current limits of car batteries, which may affect the conclusions drawn about power usage and device compatibility.
Alkemist
I saw this "AC anywhere" last week and was wondering how it works? How we can get 230 volts out of 12 volt DC supply? Isn't it drawing more power from less? [Below is the description of the Device which I'm discussing about]
Running out of power is a thing of the past with the AC Anywhere. Simply plug the unit into any 12-volt DC vehicle cigarette lighter socket and the AC Anywhere converts your vehicle's battery power to 230 volts AC (common household current.) The AC Anywhere is perfect for charging batteries for your mobile phone, portable computer, electric shaver, TV/VCR, or virtually any device while travelling. The AC Anywhere inverter features a convenient On/Off switch and fuse protection along with an audible alarm that sounds if the vehicle battery voltage drops to 10.6 volts DC.
hi Alkemist
yes they are wonderful devices :) I have one in my car for running ni cad battery chargers, laptop and other things, when out on the road stormchasing.
No, you can never do that, nothing is 100% efficient, let alone 120% or more :)
now, my unit can supply 150W @ 230VAC so ~ 1.5A. But its drawing ~ 15Amps @ 12V from the car battery to get that. Its rated efficiency is 90%.
very basically the 12V is supplied to an oscillator to generate an AC voltage. That voltage is then stepped up in a transformer to 230V
Dave
Thanks for your reply Dave.
So can I say that if a battery runs for 6 hours at 12 volt output will be drained within an hour (or may be little less or more) if we draw 230 volts from it? I mean there must be some power limitation?
Secondly can I run any kind of device on it. Like a motor of 5 HP, which requires 230 volt to operate?
davenn said:
hi Alkemist
Dave
generally I keep the car engine running if I am using the inverter, as its a pretty heavy drain on the battery. So no it wouldn't last long if it wasnt being contineously charged.
The limitations would be
1) the capabilities of the inverter
2) the car battery
3) the charging capabilities of the car system to keep the battery charged above what is being drained from it by the inverter
well yes you can run anything from it .. within the wattage rating of the inverter.
I don't know what current rating your 5 HP motor is. For example sake let's say its 5 Amps @ 230V V x A =W so 5 x 230 = 1150Watts.
So obviously my 150 W inverter aint going to do the job. I have seen inverters up to ~ 5000W. As you could imagine their current drain at 12V would be huge !
http://performanceshop.com.au/power-inverters.html?gclid=CNur1emT7qYCFQbhbgod9wfpGQ
Dave
2) the car battery
Dave
I'll check the rating of Motor I have. I have one more question. Can we get 230 v DC from 12 volt DC battery in similar way? or can we Transform that 230 AC volt output to 230 DC volt using rectifier?
for that sort of output 230VDC you would have to invert it to AC then rectify it.
for much smaller voltage changes say 12VDC to 24 or so volts DC there are nice DC to DC regulator circuits called Buck Converters.
look at datasheets for IC's like the Linear Technologies LT1071 its quite a versatile beastie :)
Dave
For clarity: Alkemist, voltage isn't power and you don't draw 120 V from a 12V battery, you draw 12V DC and convert it to 120V AC with an inverter and transformer.
Hey Russ
A small but important technical point, thanks for pointing that out :)
I hadnt picked up on that.
Dave
Davenn,
To further clarify what Russ stated:
Power = Volts * Amps
To convert voltage from one level to another:
V1 * A1 = V2 * A2 * CE
Where CE=Conversion Efficiency, and CE < 1
So, if:
V1 = 12V
A1 = 100A
then P1 = 1200W
If V2 = 240V
CE = 0.90
then
A2 = 5A * 0.90 = 4.5A
P2 = 4.5A * 240V = 1080W
Hopefully that will make it clear.
Fish
Fish4Fun said:
Davenn,
So, if:
V1 = 12V
A1 = 100A
then P1 = 1200W
If V2 = 240V
CE = 0.90
then
Fish
ahhhhhhhhh... hahaha... you have done something I hadnt figured out b4, that is how to factor in the conversion efficiency.
thanks for that
Dave
So today I checked few 3 HP and 5 HP Motors in shop. They had ratings on it something like this:
For 3 HP motor :
1] Output = 2.2 /3 kw/HP [this means 2.2 Kw and 3 HP motor], 440 Volt, 6 amp. They have not mentioned the Resistance anywhere.
2] HP = 3, Amp = 11, Volt = 230/250
For 3 HP motor the KW was in the range of 2.2 Kw - 2.80 kw.
For 5 HP motor : I just remember it is somewhat in 250 - 440 volts range and Amp of 6 - 13.
The Kw for this might be somewhere in the range of 4 to 5 Kw.
So now my question is can we run these motors on 12 - 24 volt DC inverter devices? How I can determine which inverter I should choose to run these motors? I mean KW factor? Should I need to bother about resistance factor of motor?
If the source of power is a 12 volt car battery, you might consider 20 amps as a reasonable upper limit for continuous current.
So, if you accepted this, the maximum power available would be 240 watts. (ie 12 volts times 20 amps). This is about 0.32 HP and it will be less if you include less-than-perfect efficiency.
So, although almost anything is possible, running 3 HP motors off a 12 volt system isn't really a practical proposition.
3 HP is 2238 watts and a 90% efficient inverter would have to be supplied with 2487 watts.
2487 watts at 12 volts is 207 amps.
A car battery may be able to supply this for half a minute while starting a car, but it would run flat very soon and possibly be damaged if it had to produce this current continuously.
...So the only way around that would be a bank of batteries in parallel.
That would be one way.
The Toyota Prius uses a large bank of NiMH batteries giving 201 volts at 36 HP or 27 KW.
That would be drawing a current of 134 amps.
http://www.toyota.com/prius-hybrid/specs.html
So, a series / parallel arrangement would be good, however, you would have to find a suitable inverter for whatever voltage you ended up with.
Why I'm trying to do is, I was thinking it would be cheaper to use batteries than using a Diesel engine to run 3 or 5 hp water pump motor in Agriculture irrigation purpose. Banking of batteries could be considered if it runs for couple of hours.
The place where I live have unreliable electricity supply and getting diesel is twice expensive about $ 6 / gallon. So considering the usage of around 200 - 300 hours in a year would be cheaper.
Well, you'll have to do some calculations to see if it is really economically viable: you didn't say what electricity costs and you'll have to know that to know what it costs to charge the batteries. Do the full calculation to get $ per kWh for grid power and battery power, multiply the difference by the number of hours in a year, then compare with the cost of an inverter to see how long it takes to pay back.
  • · Replies 68 ·
16K
