A Problem on Friction Coefficient
The discussion revolves around a physics problem involving two blocks, one resting on top of the other, with a focus on determining the required force to keep the top block in contact with the bottom block on a frictionless surface. The participants explore concepts related to static friction, Newton's laws, and the conditions under which the blocks remain in contact.
  • One participant proposes a formula for the required force based on the accelerations of the two blocks and the static friction coefficient.
  • Another participant questions the validity of the initial solution by considering edge cases, such as when the masses are equal or when the coefficient of friction is zero.
  • A later reply suggests using Newton's third law and provides a revised approach to the problem, emphasizing the need to consider the forces acting on both blocks.
  • Some participants express confusion about the relationship between the top mass and the entire system, particularly regarding the concept of reaction forces and their application in the context of the problem.
  • One participant clarifies the distinction between the horizontal force between the blocks and the normal force, suggesting that the friction force is crucial in maintaining contact.
  • Another participant reiterates the importance of applying Newton's second law to both the top block and the system as a whole to derive the maximum force required.
Participants exhibit a mix of agreement and disagreement. While some acknowledge the need for a systematic approach using Newton's laws, others express uncertainty about the correctness of their solutions and the interpretation of forces involved.
There are unresolved aspects regarding the assumptions made about the system, particularly in terms of the definitions of forces and the conditions under which the blocks remain in contact. The discussion reflects varying interpretations of the problem and the application of physical laws.
Hyperreality
A force F is applied on a block of mass m in such a way that it stays in contact with another block of mass M over a frictionless surface. What is the required force for the two blocks to stay in contact? The static coefficient friction between the two block is [tex]\mu_{s}[/tex].
NOTE: mass m is not in contact with the ground, and M > m.
My solution is
Acceleration on mass m is
[tex]a_{m}=\frac{F}{m}[/tex]
Acceleration on mass M is
[tex]a_{M}=\frac{F}{M}[/tex].
Since, m > M, the reaction force on m is
[tex]F_{R}=m(\frac{F}{m}-\frac{F}{M}[/tex])
Therefore,
[tex]\mu_{s}m(\frac{F}{m}-\frac{F}{M}) \geq mg[/tex]
So the required force is
[tex]F \geq \frac{Mm}{\mu_{s}(M-m)}g[/tex]
Is this correct?
Do a sanity check on your answer. What if m = M? Would the force be infinite? What if the coefficient of friction were zero? F is infinite again?
I assume the problem is to find the maximum force that you can push on the top mass without having it slide off the bottom one. What are the forces on the top mass? And on the two masses taken together? Apply Newton's 2nd law to each case.
Thank you for your help Doc Al. :blushing:
Okay, I think I might've got it.
Second attempt.
By Newton's 3rd law, there must be an equal opposite reaction force.
Using, F = (M+m)a, a = F/(M+m).
So the force on the top mass = mF/(M+m).
Action force = Reaction force. Therefore,
Reaction force = Force on the top mass + Force on the bottom mass.
Force on the bottom mass = Reaction force on the top mass.
F = mF/(M+m) + F(b)
F(b) = F - mF/(M+m).
Therefore,
[tex]\mu(F-\frac{mF}{M+m}) \geq mg[/tex]
[tex]F \geq \frac{(M+m)m}{M\mu}g[/tex]
How does it look?
After thinking about it, I think if coefficient is 0, the force would be infinite, for the friction force would equal 0.
I really don't know what you're talking about with all the action-reaction stuff. But you are getting closer. :smile:
Try this:
(1) Consider the top block. Apply Newton's 2nd law.
(2) Consider the system of both blocks together. Apply Newton's 2nd law.
Combine the equations to solve for the applied Force. (Remember, you are solving for the maximum force.)
Okay, I've been thinking about the problem, and your hints. I still don't get it.
I can't see any connection between the top mass and the whole system, and I don't see anything wrong with my second solution...
This is what I meant by the reaction force:
Since there is an applied force on the system, whomever is applying the force must experience an equal and opposite reaction force. The reaction force must come from the two blocks. So the reaction force produced by the bottom mass M must also be the reaction force on mass m.
What's wrong with that?
The connection is simple: both have the same acceleration. Part of your error is confusing the horizontal force between the two blocks (what you, for some reason, call the reaction force) with the normal force between the two blocks. (If you wish, I can go over it line by line. Let me know.)
There are severals ways to solve this problem, all equivalent.
True, if something pushes on the blocks, the blocks must push back equally. (But that doesn't help.) More usefully, the two blocks do exert equal and opposite forces on each other. And in the horizontal direction, the force they exert on each other is just the friction (which, at it's maximum, is [itex]\mu N = \mu mg[/itex]).
So let's solve this problem using the suggestions I gave earlier:
(1) Consider the top block. Apply Newton's 2nd law. This gives us:
[tex]F - \mu mg = ma[/tex]
(2) Consider the system of both blocks together. Apply Newton's 2nd law. This gives us:
[tex]F = (M + m)a[/tex]
These equations describe the horizontal forces, which is where the action is. (Note that I have assumed that the force F is applied horizontally.) I'll leave it to you to solve for the maximum force, F.
Thank you very much! :smile:
  • · Replies 59 ·
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 20 ·
