Solving Velocity Problem: Need Help with Unknowns
  • Thread starter Thread starter Afro_Akuma
    Unknowns
The discussion revolves around a velocity problem involving average speed during a car trip. The original poster seeks assistance in determining the necessary speed for the second half of the trip to achieve a specified average velocity, given that the first half was completed at a lower speed.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the unknowns in the problem, including time and distance. Some suggest setting up equations based on average speed and distance, while others question the assumptions made about the problem's parameters.
There is ongoing exploration of different approaches to the problem, with some participants providing algebraic manipulations and others questioning the validity of certain methods. Guidance has been offered regarding the interpretation of the problem and the setup of equations, but no consensus has been reached on a definitive solution.
Participants note constraints such as the requirement to use variables throughout the problem and the lack of specific distance values provided in the original question. There is also mention of the teacher's preference for algebraic solutions without substituting numerical values.
Afro_Akuma
Hello, everyone. I'm new here, drawn by a velocity problem that's had me going in circles for two days. If someone could tell me how to set this up/proceed with solving, that'd be great.
"On a car trip, you want to have an average velocity of 90km/h. Over the first half of the trip, you averaged only 48 km/h. What must your velocity be in the second half to obtain an overall average velocity of 90 km/h? Note that the velocities are based on half the distance, not half the time."
So far, I've slipped up so many times that I eventually came out with
"48 km/h = 48 km/h"
Our physics teacher is a nice guy, but he hasn't taught us well enough on dealing with many unknowns for me to be able to solve this without help.
Thanks.
Let's start slow: what are the unknowns?
hmm you should probably show some work
but
I am not sure what the problem is since it is half the distance
average equals the total of the terms divided by the number of terms
So
you have
[tex]\frac {48+x}{{2}}=90[/tex]
[tex]48+x=180[/tex]
[tex]x=180-48=132[/tex]
Note to admin: if you feel that this solution should not be posted feel free to remove but it seemed like it may help to see general form for additonal problems.
but
So
you have
[tex]48+x=180[/tex]
Oh, heck, I'll leave it in, if only because it won't help the poor guy.
It's completely wrong! You just can't average speeds over different times like that.
To Afro_Akuma: If you are concerned that the distance isn't given, maybe it doesn't matter! If you assume the total distance is 200 km, what answer do you get? If you assume the total distance is 2000 km, what answer do you get?
(By the way, I am assuming that "the first half of the trip" means half the distance, not half the time.)
wow I suck at reading
sorry i did half the time...
Answer= 720 km/hr
thats what I got
can anyone confirm?
explantion
here is how i did it
for a basic average of speed let's say you had the following
3 m/s for 5 sec
4 m/s for 8 sec
to find average you would take (15+32)/(13)
you realize you take the distances and divide it by total time
so let's test some different values for x
First I tested 2000 total
since we know each section is 1000 and we need the
[tex]\frac{rate_1*time_1+rate_2*time_2}{time_1+time_2}=90[/tex]
however since rate*time equals distance than we can make the equation
[tex]\frac{distance_1+distance_2}{time_1+time_2}=90[/tex]
so let's subsititue for 2000
sense distance1=distance2=1000
time_1= 1000/48
[tex]\frac{2000}{{\frac{1000}{48}+time_2}}=90[/tex]
therfore
[tex]2000=90(\frac{1000}{48}+time_2)[/tex]
therefore time 2 equals
125/90
therefore
since [tex]1000=(125/90)*rate[/tex]
rate equals 720
Then try it with other values to confirm you will get 720 again
here is short
using total distance equal to 96
x=time
[tex]\frac{96}{1+x}=90[/tex]
96=90+90x
6/90 = x
48= (6/90)*rate
rate=720
Sorry for answering prematurely
I honestly just misread the question... thanks for pointing it out though it was fun to do. I ended up scribbling on the back of my paper that had my essay questions for MIT lol...
Unknowns: Time (any), distance/displacement (any)
Known: No acceleration, 48 km/h velocity over half the total distance, average velocity of 90 km/h.
Yes, the "first half of the trip" meant by distance. My problem is that I can't just set an appropriate time/ditance and substitute it into the problem. The teacher's a big algebra fan. Variables all the way through to the end, no numbers that weren't sourced directly from the problem.
As for showing my work, much of it is completely useless. I've done things such as:
d
------- = 90 km/h
t1+t2
and
1/2d
------ = 48 km/h
t1
so
d
------ = 96 km/h
t1
Was I on ther right track?
d
------- = 90 km/h
t1+t2
and
1/2d
------ = 48 km/h
t1
so
d
------ = 96 km/h
t1
You are starting off okay. What you really want to calculate are the times.
Let d be the total distance, as you did. Then the person drives half the distance at 48 km/h so (1/2)d/t1= 48, d/t1= 96 (as you have). The d= 96t1 so t1= d/96. Let "v" be the speed for the second half and t2 the time. Now (1/2)d/t2= v so d= 2v t2 and t2= d/2t2. The average speed for the entire trip must be 90 km/h so, letting t be the entire time, d/t= 90 or t= d/90.
t= t1+ t2. Put the values we have, t= d/90, t1= d/96, and t2= d/2t2 into that and solve for v. You can watch d magically disappear from the equation!
was I right in my second explantion with an answer of 720 km/hr
This has been a great help to me, but I'm confused on one point:
In t2 = d/2t2, where did 2t2 come from?
I don't understand this lst part. Should it be t2 = d/2v?
Here is an algerbraic explantion
[tex]\frac{d}{time_1+time_2}=90[/tex]
[tex]time=distance/rate[/tex]
Total Distance (d)
------------------- =90
[tex]\frac{.5d}{48} + \frac{.5d}{rate_2}[/tex]
get common den
[tex]\frac {d}{.5d*rate_2+24*d}=90[/tex]
[tex]48*rate_2[/tex]
flip simplify
[tex]\frac {d*48*rate_2}{d(.5rate_2+24}=90[/tex]
[tex]48*rate_2=45*rate_2+2160[/tex]
[tex]3*rate_2=2160[/tex]
[tex]rate_2=720 km/h[/tex]
:smile:
Where did rate come in?
Actually, I figured out that rate = velocity. But could you explain the "Flip Simplify" step?
It just threw me completely how you arrived at that.
A complex fraction:
____
x
__
y
can be flipped as the denominator of the denominator is the numerator.
1*y
_______
x
Thanks! That helps a lot!
sorry I couldn't figure out how to do triple fractions with latex, but Ba was right in flipping fractions--- for simplifying I just multiply stuff out and cancel
you have to be carful somtimes though because
x
y
(XY)
what Ba simplified which is what I had was
(x/y)
  • · Replies 21 ·
21K
