Minimum value of the coefficient of static friction
The discussion revolves around a physics problem involving a block sliding on a surface and interacting with a spring. The problem includes determining the compression of the spring, the minimum coefficient of static friction required to keep the spring compressed, and the speed of the block upon detachment from the spring.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the forces involved when the spring is compressed and the relationship between the spring force and friction. There are inquiries about how to find the maximum compression distance and the necessary static friction coefficient to maintain that compression.
The discussion is ongoing, with participants sharing their thoughts on the relationships between the forces at play. Some guidance has been offered regarding the balance of forces when the spring is at maximum compression, but no consensus has been reached on the specific calculations or interpretations.
Participants are working under the constraints of the problem's parameters, including the mass of the block, the spring constant, and the coefficient of kinetic friction. There are also hints about the conditions for detachment and the role of static friction in the scenario.
physicsss
A 2.0 kg block slides along a horizontal surface with a coefficient of friction µk = 0.30. The block has a speed of v = 1.3 m/s when it strikes a massless spring head-on
(a) If the spring has a force constant k = 120 N/m, how far is the spring compressed?
(b) What minimum value of the coefficient of static friction, µs, will assure that the spring remain compressed at the maximum compressed position?
(c) If µs is less than this, what is the speed of the block when it detaches from the decompressing spring? [Hint: Detachment occurs when the spring reaches its natural length (x = 0).]
Explain why detachment occurs when the spring reaches its natural length.
I'm able to do a) but not the others. thanks for your help.
If you were able to do (a), show us your work on that at least.
Actually, I think (b) is easier than e. What's the force the spring exerts when it is compressed at the maximum compressed position?
a) 1/2mv^2-umgx=1/2kx^2.
for b, how do I find Xmax?
anyone...?
What force will pull back the string to its equilibrium position? the force -kx, is the force that brings the spring back to his position, so what minimiun value should the static friction had in order to surpass or cancel that force.
Well, for part (b) you might look at what the force of the spring happens to be when it is compressed the distance x you found in part (a). For the spring to become stationary, you must assume all the forces cancel out so, "force spring" = "force friction", with of course the new force of friction being based on some new µ-static.
how about c?
Do you understand when the block hits the spring it will compress it til it slows down, then the conservative force of the spring will start pushin the block creating a speed, and when the spring reaches its equilibrium length (x=0) it won't go on, while the block will continue moving with the speed at the equilibrium point, until the friction puts it back to rest.
  • · Replies 18 ·
12K
  • · Replies 16 ·
  • · Replies 26 ·
9K
