Solving a Linear Differential Equation with Given Conditions
The discussion revolves around solving a linear differential equation of the form u'' + u' + 2u = 0. Participants are tasked with finding the general solution and verifying specific conditions related to the solution's behavior over periodic intervals.
  • Participants explore the general solution format and verify its periodicity. They discuss the implications of specific values of Q and the initial condition u(0) = 1. Questions arise regarding the determination of u(t) for other values based on the established conditions.
The discussion is active, with participants providing insights into the periodic nature of the solution and its implications. Some have offered specific values and substitutions to further explore the relationship between u(t) and u(0), while others seek clarification on how to extend these findings to additional values of t.
Participants are working under the constraints of the problem statement, which includes specific initial conditions and periodicity requirements. There is an emphasis on verifying the solution's behavior without reaching a definitive conclusion.
TiberiusK
Find the general solution of the equation
u'' + u' + 2u = 0 of the form u(t) = C*(e^ a*t)* cos[ B*t +Q],
1)Verify that it satisfies u(t+2pi/sqrt[7])=-e^(-pi/sqrt[7])*u(t)
2)Consider a solution satisfying u(0) = 1. Determine u(2pi/sqrt[7])
For what other values of t can you determine u(t) given u(0)?
p^2+p+2=0
delta=-1
p1=-1/2+(i*sqrt[7])/2 and p2=-1/2-(i*sqrt[7])/2
=>C*(e^ -1/2*t)* cos[(sqrt[7]/2)* t +Q]=>(e^ (-t/2)-(pi/sqrt[7]))*C*cos[(sqrt[7]/2)* t +pi+Q],pi+Q=a constant=>-e^(-pi/sqrt[7])*u(t).I hope this is ok.
I also need help with 2)
You have shown that
[tex]u(t+ 2\pi/\sqrt{7})= e^{-\pi/\sqrt{7}}u(t)[/tex]
What do you get if you take t= 0 in that?
u(2pi/sqrt[7])=-e^(-pi/sqrt[7])*u(0),where u(0) = cos[ Q]
For Q=0,or 2pi u(0)=1=>u(2pi/sqrt[7])=-e^(-pi/sqrt[7])...
And for the part "For what other values of t can you determine u(t) given u(0)"?
Does someone have any advice?
Now that you know [itex]u(2\pi/\sqrt{7})[/itex] do the same: use
[tex]u(t+2\pi/\sqrt[7])=-e^(-\pi/\sqrt[7])*u(t)[/tex]
setting [itex]t= 2\pi/\sqrt{7}[/itex].
Then with [itex]t= 4\pi/\sqrt{7}[/itex], [itex]t= 6\pi/\sqrt{7}[/itex], etc.
just substitute t with the above values in this formula u(t+2pi/sqrt[7])=-e^(-pi/sqrt[7])*u(t)...ok...thank you
  • · Replies 18 ·
  • · Replies 105 ·
13K
  • · Replies 21 ·
