How to Calculate Net Magnetic Force on a Current Loop?
The discussion revolves around calculating the net magnetic force acting on a current loop, with participants exploring the principles of magnetism and forces on current-carrying wires.
  • Participants discuss how to calculate the magnetic force on a current loop, questioning whether to evaluate forces at specific points or consider the entire loop. There are inquiries about the magnetic field produced by straight wires and the forces acting on the loop's vertical segments.
Several participants have offered insights into the symmetry of forces on the vertical wires, suggesting that forces on opposite sides cancel each other out. There is ongoing exploration of the right-hand rule for determining directions of forces and magnetic fields, with some seeking clarification on its application.
Participants are navigating the complexities of magnetic interactions and the implications of current direction, with some expressing confusion about the right-hand rule and the orientation of magnetic fields relative to current. There is mention of a figure that may provide additional context, though it is not included in the discussion.
jegues
See figure attached.
I'm confused as how to calculate the net magnetic force that acts on the loop.
Do I choose a point somewhere and calculate the magnetic force with respect to that? Because I don't quite understand how to calculate the magnetic force with respect to an entire loop.
Any ideas?
Thanks again!
can you find mag field at any point due to a straight wire?
and also force on a straight wire due to mag field?
The magnetic field due to current in a straight wire is simply,
[tex]B = \frac{\mu_{0}i}{2 \pi R}[/tex]
The force on a straight wire would be,
[tex]\vec{F_{b}} = i\vec{L}\times \vec{B}[/tex]
but I'm still not seeing how to obtain the net force on the loop?
i am guessing that you have problem with finding the force on the vertical wires of the loop ...
well for that, consider any element dx at distance of x from wire on both vertical wires of loop ... as you can see that the force equal will be opposite on the 2 dx elements ... same will happen on all the elements on the vertical wire ... so net force on the vertical wires of loop wil be ... ?
Zero. When I originally attempted this question I did this as well but I got the wrong answer.
isnt the answer d?
How come the wire with the 12A running through it doesn't have any effect on the vertical wires?
it has effect ... but its opposite on 2 wires ... that's why is gets canceled and you can ignore it.
How can I verify this using right hand rule I always get confused...
How am I suppose to orient my fingers? (I'm using my index finger, my middle finger, and my thumb, where the thumb is the resultant vector of the cross product of the index finger and middle finger.)
Thanks again!
EDIT: Is the magnetic field always perpendicular to the current in the wire?
Then I would point my index finger in the direction of the current, my middle finger perpendicular to my index finger and my thumb out to the side.
Is this correct?
for Fleming's Rule(which include middle finger, index finger, thumb) -- like for AXB ... the index finger should be along A and midddle finger along B ... then thumb will give direction of the resultant
Note: if it was BXA ... index finger will be along B and middle finger along A
consider this: http://cyclo.mit.edu/~schol/802x/howtos/rhr_howto.pdf however i always prefer using right hand thumb rule ...
why i like it is because it eliminate both right and left rules (which include middle finger, index finger, thumb)
you know how to use it to find the direction of mag field due to straight current ...
for cross product ...
open your hand ... for AXB the four fingers should be pointing towards A and when you curl your hand ... fingers should go towards B ... the thumb will give the direction of force
which wire are we talking about?
Well because we are looking at the force,
I know that the L vector points along the direction of current, so I orient my index finger in that direction, but how do I know what direction B points towards? I need to oriente my middle finger in this direction I can determine the direction of the resultant force.
Can you clarify? I know how to use right hand rule, I just don't see how to get the direction of B.
from thumb rule you know that field is circular with wire at center ...
so for any plane ,,, field will be perpendicular to the plane ,, and in this case as you case ... it will vertically downwards at the loop
but i will still advice you to use thumb law
  • · Replies 37 ·
