Applying Von Hann Windowing to a Data Set with N=3144
  • Thread starter Thread starter andrey21
The discussion focuses on applying the Von Hann windowing technique to a data set with N=3144 terms. The formula for the Von Hann window is defined as w(n) = 0.5 - 0.5 cos(2 * PI * n / N), where n ranges from 0 to N-1. Participants confirm that to apply the window, each data element x(n) should be multiplied by the corresponding w(n). For improved symmetry, it is recommended to use w(n) = 0.5 - 0.5 cos(2 * PI * n / (N-1)) or to consider the Hamming window, w(n) = 0.54 - 0.46 cos(2 * PI * n / (N-1)).
  • Understanding of windowing functions in signal processing
  • Familiarity with the Von Hann and Hamming window formulas
  • Basic knowledge of trigonometric functions
  • Experience with data manipulation in programming environments
  • Implement the Von Hann windowing technique in Python using NumPy
  • Explore the differences between Von Hann and Hamming windows in practical applications
  • Learn about the effects of windowing on frequency analysis
  • Investigate other windowing techniques such as Blackman and Bartlett
Data analysts, signal processing engineers, and anyone interested in applying windowing techniques to time series data.
andrey21
I have been asked to apply a suitable window to a data set, for this I have chosen Von Hann's approach
This is the formula I know must be used
w(n) = 0.5-0.5 cos (2* PI* n/N)
where n = 0,1,2,3...N-1
N= number of terms
My question is how do I apply this to an already given data set, with N=3144? Do I simply use n=0,1,2 or other values.
N= number of terms
Yes just use n-0,1,2,..N-1 and simply multiply each element x(n) of your data by the corresponding w(n) of the Window.
Notes.
1. Consider using w(n) = 0.5-0.5 cos (2* PI* n/(N-1)) for better symmetry.
2. Even better to use the Hamming Window. w(n) = 0.54-0.46 cos (2* PI* n/(N-1))
Thank you uart, so as my data set consists of 3144 terms the equation for either Von or Hamming would be:
w(n)= 0.5-0.5cos(2*PI*n/3143)
or
w(n) = 0.54-0.46cos(2*PI*n/3143)
Also is it more common to use N-1 rather than N as you said for better symmetry, I have only seen N used that's all. Thank you
10K
