There HAS to be a mistake in this question (simple vectors question) please look
  • Thread starter Thread starter Femme_physics
    Mistake Vectors
The discussion revolves around a problem involving vector forces, specifically the calculation of two forces, Q and F, that combine to create a resultant force R acting on a point O. The original poster expresses confusion regarding the relationship between the magnitudes of these forces and the resultant force.
  • Exploratory, Assumption checking
  • The original poster questions the validity of the given values for forces Q and F, particularly noting that Q appears to exceed the magnitude of the resultant force R. Other participants explore the implications of a potential mistake in the problem statement.
Participants are actively engaging with the problem, with some suggesting that there may be an error in the question itself. Various interpretations of the vector directions and magnitudes are being discussed, but no consensus has been reached regarding the correct values or setup.
There is mention of a possible mistake in the problem statement regarding the value of the resultant force, which some participants believe should be different from what is provided. Additionally, there are references to the visual representation of the forces, which may be contributing to the confusion.
Femme_physics
Force R that acts on point O, is the combined force of two forces: Q that's applied horizontally, and F, whose line of action is along OB. (I think it ought to be an arrow there instead of a line)... Calculate Q and F, if R is 550 [N]
http://img87.imageshack.us/img87/705/38305098.jpg
Well, as you can see, R - the combined vector, is not pointing where it should! That doesn't make sense.
In addition, according to the answers
Q = 568.58 [N]
F = 197.47 [N]
How can Q be greater than the combined vector if they're not opposite to each other?
-Femme_physics (formerly Dory)
Sorry, I fixed the image now
Ah I see it for myself now.. it acts ALONG OB, the arrow is actually reverse from the drawn line...
Trying to solve for the question at hand...no result I get is the correct result... :(
What am I doing wrong? I tried 3 different triangles and none of them work!
Hi Femme_physics! :smile:
Why did you change your name?
(It wasn't something I said, was it?)
Nothing … the whole universe is against you! :redface:
The question should say 500, not 550. :biggrin:
(I checked using the sine rule)
Ah...w00t! :) So there IS a mistake!
Yes! Yes it was! But, it just reinforced my feelings that Dory can be construed as a MALE name as opposed to female... so I changed it... on second thought I should've went with Dora, but I don't want to drive the mods here crazy so I'll leave it as is...thanks tim!
14K
  • · Replies 29 ·
