Designing Comparator with Discrete BJTs
The discussion revolves around designing a comparator using discrete BJTs (Bipolar Junction Transistors). Participants explore various configurations, such as emitter coupled pairs, and discuss the necessary components and considerations for achieving desired functionality and performance.
  • One participant suggests using an "emitter coupled pair" for a simple comparator but notes the need for current mirror biasing and an output stage for better functionality.
  • Another participant inquires about fixing the gain of the circuit and overcoming the minimum Vbe requirement for the transistors in the emitter coupled pair configuration.
  • A participant proposes that a BJT configured as a common emitter amplifier with a Vcc of 5V could serve as a TTL output comparator.
  • Concerns are raised about the mismatch and offset when using separate transistors instead of a matched pair, especially under varying temperatures.
  • One participant modifies an existing circuit to create a simple comparator design, explaining the biasing method and the expected behavior of the output based on input voltage differences.
  • Common mode input range is identified as a significant issue due to the simple resistor biasing, prompting suggestions for improvement through current mirror biasing.
Participants express various approaches to designing the comparator, with no consensus on a single method or configuration. Multiple competing views on the effectiveness of different designs and components remain present throughout the discussion.
Participants mention limitations related to biasing methods and the accuracy of the comparator design, indicating that the proposed solutions may not yield high precision due to the use of simple components and configurations.
This discussion may be useful for individuals interested in analog circuit design, particularly those exploring the use of discrete BJTs in comparator applications.
likephysics
Just wondering how would one design a comparator using just discrete BJTs.
An "emitter coupled pair" makes a simple comparator, but you'd need to include current mirror biasing and an output stage to make anything that even approached the sort of functionality of commercially available IC's.
How simple or how elaborate do you want it?
Emitter coupled pair like the one in attachment?
I've been playing with this since yesterday. How do you fix the gain of this ckt.
In the ckt, how do I overcome the min Vbe requirement of Q1,Q2.
For a TTL output comparator a BJT configured as a CE amplifier with Vcc=5v would work?
I just need something that works and also simple enough to understand.
You forgot the attachment :)
huh. Here it is.
To make a discrete differential pair, you will usually use a matched transistor pair. There is too much mismatch/offset when you use separate transistors, especially over temperature:
http://www.google.com/imgres?imgurl...en&gbv=2&tbs=isch:1&ei=eYtRTaKcCo72swPtkPy9Bg
likephysics said:
huh. Here it is.
Ok I modified your circuit to make about the simplest "comparator" possible out of a few discrete components.
The 10k base resistors will bias the inputs to just below zero volts (about -50mV). It will work better with matched transistors but this is not meant to be a particularly accurate comparator so it doesn’t really matter. It’s definitely only meant as a simple project to explore the most basic aspects of BJT comparator design.
It’s biased so that the output is just off (low) when the two input voltages are at zero and it will switch high when V2 gets about 50mV higher than V1.
Common mode input range is a big problem due to the simple resistor biasing. You might want to explore how you can improve the design with current mirror biasing.
BTW. Q3 could be any general purpose PNP transistor, I just chose the 2N2907A because you seem to be basing other components around the pspice evaluation library.
  • · Replies 0 ·
