How to Calculate F_t and N for a Roller on a Cam Mechanism?
The discussion focuses on calculating the tangential force, F_t, and the normal force, N, acting on a roller in a cam mechanism described by the function r = r_0(2 - cos θ), with r_0 set at 2.25 ft. The roller, weighing 25.6 lb, is subjected to a constant angular velocity of 0.85 radians/s. Key calculations include determining the radial acceleration, a_r, and tangential acceleration, a_t, using the equations of motion, ultimately leading to the forces F_t and F_n derived from these accelerations.
  • Understanding of polar coordinates and cam profiles
  • Knowledge of angular motion and acceleration concepts
  • Familiarity with Newton's laws of motion
  • Ability to apply force equations in mechanical systems
  • Learn how to calculate angular acceleration in mechanical systems
  • Study the principles of cam design and analysis
  • Explore the effects of spring forces in dynamic systems
  • Investigate the relationship between tangential and normal forces in circular motion
Mechanical engineers, students studying dynamics, and anyone involved in the design and analysis of cam mechanisms will benefit from this discussion.
sami23
A cam has a shape that is described by the function r = r_0(2 - cos [tex]\theta[/tex]), where r_0 = 2.25 ft. A slotted bar is attached to the origin and rotates in the horizontal plane with a constant angular velocity ([tex]\dot{\theta}[/tex] dot) of 0.85 radians/s. The bar moves a roller weighing 25.6 lb along the cam's perimeter. A spring holds the roller in place; the spring's spring constant is 1.75 lb/ft. The friction in the system is negligible. When [tex]\theta[/tex] = 102 degrees, what are F_r and F_[tex]\theta[/tex], the magnitudes of the cylindrical components of the total force acting on the roller?
r = r_0(2 - cos [tex]\theta[/tex]) = 2.25(2-cos102) = 4.9678 m
[tex]\dot{\theta}[/tex] = 0.85 rad/s
[tex]\ddot{\theta}[/tex] = 0 rad/s2
[tex]\dot{r}[/tex] = (r_0sin[tex]\theta[/tex])([tex]\dot{\theta}[/tex]) = 2.25(.85)sin(102) = 1.87 m/s
[tex]\ddot{r}[/tex] = (r_0cos[tex]\theta[/tex])([tex]\dot{\theta}[/tex])^2 + (r_0sin[tex]\theta[/tex])([tex]\ddot{\theta}[/tex]) = 2.25(.852)cos(102) = -0.338 m/s2
a_r = [tex]\ddot{r}[/tex] - r([tex]\dot{\theta}[/tex])^2
a_[tex]\theta[/tex] = r[tex]\theta[/tex] + 2[tex]\dot{r}[/tex][tex]\dot{\theta}[/tex]
F_r = W/g * a_r
F_[tex]\theta[/tex] = W/g * a_[tex]\theta[/tex]
F_s = ks (spring)
a_r = [tex]\ddot{r}[/tex] - r([tex]\dot{\theta}[/tex])^2 = -0.338 - 4.9678(.85^2) = -3.927 m/s2
a_[tex]\theta[/tex] = r[tex]\theta[/tex] + 2[tex]\dot{r}[/tex][tex]\dot{\theta}[/tex] = 4.9678*0 + 2*1.87*.85 = 3.179 rad/s2
F_r = W/g * a_r = (25.6/32.2)*(-3.927) = 3.12 lb
F_[tex]\theta[/tex] = W/g * a_[tex]\theta[/tex] = (25.6/32.2)*(3.179) = 2.53 lb
But it's wrong and I didn't consider the spring force. How do I incorporate Fs? Please help. I'm stuck
it opposes the acceleration along r
I found F_r = -3.122 lb and F_[tex]\theta[/tex] = 2.531 lb when a_r = -3.927 rad/s2 and a_[tex]\theta[/tex] = 3.179 rad/s2
What are F_t and N, the magnitudes of the tangential force, F_t, and the normal force, N, acting on the roller when [tex]\theta[/tex] = 102 degrees?
a = a_t + a_n
a_t = dv/dt (angular velocity)
a_n = v2/[tex]\rho[/tex] where [tex]\rho[/tex] = radius of curvature
Equations of Motion:
F_t = W/g * a_t
F_n = W/g * a_n where g = 32.2 ft/s2
How do I find a_t and a_n to get the tangential force and the Normal? Please help.
