Cylinder head and Cylinder block
The discussion centers on the operating conditions for cylinder heads and blocks in diesel and gasoline engines, focusing on numerical values for temperature and pressure, as well as mechanical loading and failure modes. Participants seek to clarify the environmental factors affecting these components.
  • Homework-related
  • One participant requests specific numerical values for temperature and pressure that cylinder heads and blocks must withstand, indicating a need for detailed operational data.
  • Another participant questions the purpose of the inquiry, suggesting that understanding the context is important for providing relevant information.
  • A participant mentions they are writing a case study report and seeks background information on operating environments, mechanical loading, and failure modes, indicating a research-oriented approach.
  • One response provides general ranges for cylinder wall and flame face temperatures (a few hundred Celsius) and peak cylinder pressures (80 - 200 bar), emphasizing that these values depend on engine type and application.
  • A participant specifies they are interested in both 4-stroke gasoline and diesel engines, seeking to define the operational environments for these components.
  • Another participant asserts that 'normal' operating conditions fall within the previously mentioned temperature and pressure bands.
  • A participant shares an anecdote about a specific engine's performance under flawed conditions, illustrating the impact of mechanical load on engine durability.
  • One participant inquires about the types of mechanical loadings that engine blocks experience, seeking further technical clarification.
Participants have not reached a consensus on specific numerical values or detailed operating conditions, and multiple competing views regarding the context and requirements for the information remain evident.
The discussion reflects limitations in available data and the need for clarification on definitions and specific engine types, which may affect the interpretation of operating conditions.
ruzfactor
can some one please refer me operating conditions for cylinder head and block of diesel and gasoline engines. I have searched through google but couldn't find any definite info on that. I need numerical values of temperature, pressure that head and block must withstand.
welcome..
you ask two things
operating conditions for gas IC and diesel engine
then you asked for worst case conditions...
may i ask..what is purpose of your post?
Actually I'm writing a case study report on cylinder block and head materials development. I need to provide a brief background such as operating environment, mechanical loading and failure modes of cylinder block and head. I have done my research on materials but I couldn't find any specific data or range of data on these background topics. I really need help here.
What sort of engines?
Cylinder wall and flame face temperatures might be a few hundred Celsius. Peak cylinder pressure might be between 80 - 200 bar. It completely depends on the type of engine, application, operating conditions etc.
both for 4stroke gasoline engine and diesel engine cars. I really need to define operation environments that cylinder block and cylinder head normally experience.
Well 'normal' falls within the bands I outlined.
I know that a 350 cid engine that is making about 530 hp and 500 lb.ft of torque (injected alcohol Sprint car) using a block that has a cylinder wall with a casting flaw that reduces the thickness to about 0.090" will survive about two hours on the dyno before splitting ...
what type of mechanical loadings engine blocks experience? Please explain.
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 39 ·
