Prove or disprove this inequality
  • Thread starter Thread starter kakarukeys
    Inequality
The discussion revolves around proving or disproving the inequality Aa + Bb + Cc + Dd > 0, given certain conditions on the variables a, b, c, d, A, B, C, and D. The context includes inequalities and relationships between these variables, with a focus on mathematical reasoning and geometric interpretations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants have attempted various mathematical techniques, including the use of Lagrange Multipliers and the Cauchy-Schwarz inequality. Some participants question the assumptions regarding the positivity of certain variables and explore geometric interpretations of the problem.
The discussion is ongoing, with participants sharing insights and attempting to clarify the relationships between the variables. Some have provided guidance on potential approaches, while others express uncertainty about the implications of their findings.
There are discussions about the conditions under which the variables are defined, such as whether certain variables are greater than zero or if they satisfy specific inequalities. Participants are also considering the implications of working in different dimensions.
kakarukeys
:confused:
[tex]a^2 - b^2 - c^2 - d^2 > 0[/tex]
[tex]A^2 - B^2 - C^2 - D^2 = 1[/tex]
[tex]A > 1[/tex]
[tex]a > 0[/tex]
Prove or disprove [tex]Aa + Bb + Cc + Dd > 0[/tex]
after 3 days of trying I give up
can anyone give a clue?
what I have done:
I used [tex](a + b)^2 = a^2 + b^2 + 2ab[/tex], but it leads to nothing.
I have tried Lagrange Multipliers, but the only extremum is a saddle point.
trying to disprove it
I found no counter-example.
(a+A)^2 + (b+B)^2 + (c+C)^2 + (d+D)^2 > 0
-- AI
I can't see.
then?
Are b,c,d >0 and B,C,D>1 ?? if so, no need to prove anything since it is obvious.
If not, I think we can't say the given formula >0 or <0
You can try subsitute some values of b,c,d to guess a, then values for B,C,D to calculate A, you will see it.
Am I incorrect ?
Let me try to give some motivation about the inequaility.
Consider the equivalent problem in 2D. That is,
[tex]a^{2}-b^{2}>0, a>1[/tex]
[tex]A^2-B^2=1, A>1[/tex]
Prove or disprove [tex]aA+bB>0[/tex]
In 2D, the region represented by the first equation is like a "quadrant" rotated by 45 degrees. (Try to plot it.) The set represented by the second equation is one component of a hyperbola included in the first region. Note that Aa+Bb is just the usual *dot product* between vector (a, b) and (A, B). Can you see why the inequality holds in the case?
Try to do the problem for 3D and then generalise it.
Wow, my gal bit me .:redface:
To Wong,
The angle between the vectors is always less than 90?
I can see it in 2D and 3D, but not in 4D, but how to write a proof?
hi kakarukeys.
To prove it, first note that the set represented by [tex]a^{2}-b^{2}-b^{2}-c^{2}=1, a>1[/tex] is in fact a subset of [tex]A^2-B^2-C^2-D^2>0, A>0[/tex]. Then what we need to prove becomes
Prove [tex]Aa+Bb+Cc+Dd>0[/tex], where (A, B, C, D) and (a, b, c, d) both satisfies,
[tex]h^2-i^2-j^2-k^2>0, h>0[/tex]
[tex]A^2>B^2+C^2+D^2[/tex]
[tex]A>(B^2+C^2+D^2)^{\frac{1}{2}}[/tex]
Similarly,
[tex]a>(b^2+c^2+d^2)^{\frac{1}{2}}[/tex]
Put those expression into Aa+Bb+Cc+Dd, does it remind you of some inequality?
This can be generalised to any dimensions.
Somtimes it can be quite difficult to think of a proof for inequalities, even though it is quite trivial geometrically.
Intuitive guide, I have spotted the 'subset' clue.
but I still can't see the solution.
[tex]Aa > \sqrt{B^2 + C^2 + D^2}\sqrt{b^2 + c^2 + d^2} \geq Bb + Cc + Dd[/tex]
(Cauchy-Schwarz inequality)
And so [tex]Aa - Bb - Cc - Dd > 0[/tex]
that's not we want.
Note [tex]Bb + Cc + Dd[/tex] can be negative.
ok COOL
[tex]Aa > \sqrt{B^2 + C^2 + D^2}\sqrt{b^2 + c^2 + d^2} = \sqrt{(-B)^2 + (-C)^2 + (-D)^2}\sqrt{b^2 + c^2 + d^2}<br /> \geq - Bb - Cc - Dd[/tex]
Thumbs up!
Interesting indeed!
I was lost with my initial thoughts !
Bravo!
-- AI
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 21 ·
