Pressure of water in a sealed container
The pressure of water in a sealed container can be determined using the ideal gas law and the principles of thermodynamics. When water is heated from temperature T1 to T2, the change in pressure can be calculated by applying the coefficients of compressibility and thermal expansion, which are assumed to be constant. Relevant equations include the Clausius-Clapeyron relation and the ideal gas equation. Providing known values such as initial pressure and volume is essential for accurate calculations.
  • Understanding of the ideal gas law
  • Familiarity with the Clausius-Clapeyron relation
  • Knowledge of coefficients of compressibility and thermal expansion
  • Basic thermodynamics concepts
  • Research the Clausius-Clapeyron relation for phase changes
  • Learn about the ideal gas law and its applications
  • Study the coefficients of compressibility and thermal expansion in fluids
  • Explore thermodynamic properties of water at varying temperatures
Students and professionals in physics, engineering, and environmental science who are studying fluid dynamics and thermodynamics, particularly those interested in the behavior of water under varying temperature and pressure conditions.
2slowtogofast
If you have water in a sealed container at one temp T1 and the you heat the water to temp T2 how could i find the pressure with just this info. Also assumeing the coefficents of compressibility and thermal expansion are constant.
As per forum guidelines you need to show some working before we can help you.
Do you know any relevant equations? What about any known values?
  • · Replies 16 ·
  • · Replies 56 ·
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 19 ·
