Finding the eigenvalues of maps of polynomial vector spaces
This discussion focuses on finding the eigenvalues and their geometric multiplicities for two linear maps on the vector space of real-coefficient polynomials of degree less than five. The first map, defined as G(f) = xD(f), involves differentiation and leads to a system of equations for eigenvalues. The second map, F(f), multiplies the polynomial by (2+x^3) and truncates higher degree terms, resulting in a similar eigenvalue problem. The discussion emphasizes the need to analyze both zero and non-zero eigenvalues to fully understand the behavior of these operators.
  • Understanding of eigenvalues and eigenvectors in linear algebra
  • Familiarity with polynomial functions and their properties
  • Knowledge of differentiation as a linear operator
  • Basic concepts of ordinary differential equations
  • Study the properties of linear operators on polynomial spaces
  • Learn how to derive eigenvalues from differential equations
  • Explore the geometric multiplicity of eigenvalues in vector spaces
  • Investigate the implications of polynomial truncation on eigenvalue problems
Mathematics students, educators, and researchers interested in linear algebra, differential equations, and polynomial vector spaces will benefit from this discussion.
cloverforce
Let V be the vector space of all real-coefficient polynomials with degree strictly less than five. Find the eigenvalues and their geometric multiplicities for the following maps from V to V:
a) G(f) = xD(f), where f is an element of V and D is the differentiation map.
b) F(f) is obtained by multiplying f by 2+x^3 and crossing out all terms of degree five or greater
None I can think of.
For a), I wrote out that if v is an eigenvector, then for it there exists some h such that G(v) = h*v = h(a4*x^4+...+a1*x+a0) = 4*a4*x^4 + 3*a3*x^3+...+a1*x and from this tried to set up equations such as h*a4 = 4*a4,.., h*a1=a1, h*a0= 0, and so on. But from here I'm not sure how to solve for the eigenvalues. I've never done this before and there has been no explanation either in lecture or in the book of how to approach this kind of problem.
For b), I did the same and came up with F(v) = h*v = (2*a4+a1)*x^4 + (2*a3+a0)*x^3 + 2*a2*x^2 + 2*a1*x + 2*a0 (this is what happens when one simplifies the polynomial and crosses out the summands with terms of degree five or higher). Again, not sure what to do from here.
Given an operator f, I think it's usually easier to consider two cases: 1. the eigenvalue is 0 (considered when Ker f =/= {0}), 2. the eigenvalue is not 0.
For instance, in part a), you can easily check which polynomials are eigenvectors with eigenvalue 0. Then just suppose that the eigenvalue h is not 0, and then using the systems of equations you've written out it's pretty easy to see what h could be. Note the obvious reinterpretation of problem a) as a first order separable ordinary differential equation, which leads to slick solution.
  • · Replies 24 ·
  • · Replies 58 ·
