How maximum and minimum thermometers work?
  • Context: High School
  • Thread starter Thread starter Fabio Naia
    Maximum Minimum Work
Maximum and minimum thermometers operate using two mercury columns that respond oppositely to temperature changes. When the temperature increases, a clear liquid in the minimum column expands, pushing mercury up in the maximum column while simultaneously pushing mercury down in the minimum column. Conversely, when the temperature decreases, the liquid contracts, causing mercury to rise in the minimum column and fall in the maximum column. This dual mechanism allows for accurate temperature readings in both directions.
  • Understanding of thermodynamic principles
  • Familiarity with liquid expansion and contraction
  • Basic knowledge of mercury as a temperature measurement tool
  • Awareness of the structure and function of thermometers
  • Research the properties of mercury in temperature measurement
  • Explore the design and functionality of different types of thermometers
  • Learn about the principles of thermal expansion in liquids
  • Investigate the historical development of thermometric devices
Students in physics, engineers involved in temperature measurement, and anyone interested in the mechanics of thermometers will benefit from this discussion.
Fabio Naia
How maximum and minimum thermometers work??
hi...
Maximum and minimum thermometers has two mercury columns. One column goes up when temperature increases and the other column goes down when temperature increases (they work in opposite directions). How this is possible?
Please send some help...
thanks
Fabio
Science news on Phys.org
Fabio Naia said:
hi...
thanks
Fabio
Hi Fabio,
The Minimum column above the mercury is filled with a clear liquid which expands with temperature. When the temperature rises, the liquid expands and pushes the mercury up the Maximum column this also pushes the mercury down in the Minimum column.
When the temperature falls, the liquid contracts and pulls the mercury up the Minimum column which also causes the mercury to fall in the Maximum column.
Reference: http://lib.store.yahoo.net/lib/yhst-63803600799585/5458troubleshooting.pdf
Ced.
It's good that he has an answer now, but if you look at the date, he's probably no longer waiting for it.
  • · Replies 42 ·
