DE Help - Solve dy/dx=(-x+sqrt(u))/y
  • Thread starter Thread starter aatkins09
The discussion revolves around solving a differential equation of the form dy/dx = (-x + sqrt(x^2 + y^2)) / y, with a proposed substitution of u = x^2 + y^2. Participants are exploring methods to simplify the equation and find a solution.
  • Participants discuss using substitution and implicit differentiation to simplify the problem. There are attempts to integrate and concerns about the complexity of the resulting expressions. Some participants question the effectiveness of their substitutions and seek clarification on how to proceed with the differentiation.
Several participants have provided guidance on using implicit differentiation and substitution. There is an acknowledgment of the challenges faced in simplifying the expressions, with some expressing uncertainty about their progress. The discussion remains active with multiple interpretations being explored.
Participants mention difficulties in achieving a clean solution and express a need for further assistance. There is a focus on ensuring that the correct substitutions are made and that implicit differentiation is applied properly.
aatkins09
dy/dx=(-x+sqrt(x^2+y^2))/y
USE SUBSTITUTION u=x^2+y^2
I tried to work it out but got a really ugly answer, please help!
If you use the correct substitution then several things should cancel. It would be helpful to also post your attempt at the solution in order to see where you are having problems.
I got
int(y dy)=int(-x+sqrt(u))dx
which turned into
y^2/2=(1/-2+2y)*int(sqrt(u) du)
which equals
-1/2+2y*2/3u^3/2
which then gets down to
y^2/2=(-u^(3/2))/3-3y
and then it gets uglier when I try to get y by itself
I know I am messing up somewhere but cannot pin point it
Instead of starting out by trying to separate and integrate, try finding an expression for du/dx and using it to replace dy/dx
du/dx would be 2x+2y but I don't understand where to go from there. how can I replace dy/dx with it?
Remember that you have to use implicit differentiation.
[tex]du=2xdx+2ydy[/tex]
Then you can solve for [tex]dy/dx[/tex]
You should find that when you find this and substitute, several things should cancel.
I did it (in my head, not on paper yet) and I'm pretty sure I've got it! thank you so much, I appreciate all of your help!
nvm, I still can't get it. it's okay though, thank you, I appreciate all of your help!
[tex]\frac{du}{dx} = 2x+2y \, \frac{dy}{dx}[/tex]
Now just substitute in your original expression for dy/dx and it literally just falls into place.
Thanks so much :)
