Proving the number of solutions to |a|+|b|= k
  • Thread starter Thread starter brztgkj
The discussion revolves around proving the number of solutions to the equation |a| + |b| = k, specifically that there are 4k pairs of (a, b) that satisfy this equation. The subject area includes absolute values and combinatorial reasoning.
  • Participants explore various cases based on the values of a and b, particularly considering scenarios where neither is zero and where one or both may be zero. They discuss counting methods for positive integers and permutations of signs and orders.
Participants have shared their attempts at deriving the number of solutions, with some suggesting different approaches and breaking down the problem into cases. There is an ongoing exploration of how to simplify the reasoning and connect the cases effectively.
Some participants express uncertainty about the best way to approach the problem and question the assumptions underlying their reasoning. There is mention of specific values for k and how they affect the number of solutions, as well as the need to prove certain relationships between variables.
brztgkj
Prove that there are 4k solutions to the equation |a|+|b| = k, i.e. 4k pairs of a and b such that |a|+|b|=k.
none
I've written out the first few:
for k = 0, the only solution is (0,0)
for k =1, we have (-1,0) (0, -1) (0,1)(1,0)
for k =2, we have (1,1) (-1, -1)(-1,1)(1,-1) (0,2)(2,0)(-2,0)(0,-2)
for k =3, we have (2,1)(1,2)(-2,1)(1,-2)(2,-1)(-1,2)(-1,-2)(-2,-1)(0,3)(3,0)(0,-3)(-3,0)
The pattern seems to involve looking at the order/sign permutations of the pairs. The total number of solutions seems to be:
4(for the permutations made by sign changes and flipping the order of the (0,k) pair) + n*8(where n is the number of pairs where a doesn't equal b and neither a nor b equals 0, and 8 is the number of permutations made by sign changes and flipping the order)+4 (if there is a pair where a=b (i.e. if k is even) for the sign/ordering permutations).
Then I would need to prove that n=(k-1)/2 rounded down, and prove k=0 and k=1 separately. I think proving what n equals could be accomplished by arguing that the first pair (in which the two elements are not equal) must be either ((k/2)+1, (k/2)-1) (if k is even) or ((k-1)/2, (k+1)/2) (if k is odd), and that there are only k/2 rounded down more pairs.
It seems like there should be an easier way of doing this, but I'm stuck at the moment. Any suggestions?
none
I would think about this in 2 cases:
Case 1) neither a nor b is 0.
Case 2) either a or b is 0.
Now, let's look at Case 1.
First, let's just consider the case where a and b are both positive. So, how many ways can we write k as the sum of two strictly positive integers. Write k like this:
[tex]k=1 + 1 + \cdots + 1[/tex]
So now, realize that there are k-1 gaps between the 1's. Put an imaginery divider between each of these gaps and regard all the 1's to the left of the gap to be a and all of the 1's to the right of the gap to be b. There are k-1 different gaps, so there are k-1 different ways to pick two POSITIVE integers whose sum is k. But that isn't all of the story for Case 1 because for each (a,b) the pairs (-a,b), (-a,-b), (a,-b) are all solutions, so there are 4(k-1) solutions for Case 1.
Now think about Case 2.
Also, I would probably clean up what I wrote a little and try to fit it all into 1 case (which can be done, btw).
Yes--I see how Case 2 fits in conceptually at least. I'm thinking about it as [tex]k=0 + 1 + 1 + \cdots + 1 + 0[/tex]
and then the same argument for gaps between 1s, but for the gaps between a zero and a one, there are only 2 solutions (a, 0) and (-a, 0) for the 0+1+... gap and (0, -a) and (0, a) for the ...+1+0 gap?
btw, I think that that was a beautiful solution, and I'm not going to use it on my homework because I wouldn't have gotten there by myself. Do you have any advice for coming up with simple solutions like that instead of the confusing mess that I did?
Yes, you got it. As far as advice, just try to break stuff down to things that you know or think you can figure out. So, |a|+|b|=k is kind of whacky at first, but I just thought about it in terms of positive integers, which I knew how to handle (or at least, knew I could figure it out). But, as you might have seen, this can be generalized, for example how many solutions are there to:
[tex]x_1 + x_2 + \cdots + x_n = k[/tex]
where all the [tex]x_i[/tex]'s are positive?
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 18 ·
