New Reply
how does the pressure difference over a NACA 0012 affects its characteristics?
Share Thread Thread Tools
Feb13-11, 02:27 PM   #1
I wanted to know how does the pressure difference (on the upper and lower surface) affect the performance of the airfoil? That is, if the pressure difference is high/low, how does that affect the characteristics of the airfoil, taking naca 0012 as example, for increased angle of attack, the pressure distibution vs x/c changes. How do we account for that?
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb13-11, 08:05 PM   #2
As the angle of attack increases, the pressure difference between the upper and lower surface increases. The upper surface pressure drops very rapidly, for most airfoils this is most noticeable by observing the minimum pressure spike near the leading edge on the upper surface. This pressure difference creates lift. The pressure distribution can also create a torque on the airfoil which is referred to as the pitching moment.
New Reply
Thread Tools
Similar Threads for: how does the pressure difference over a NACA 0012 affects its characteristics?
Thread Forum Replies
Pressure difference Engineering, Comp Sci, & Technology Homework 1
Naca 0015 Mechanical Engineering 6
How pressure and temperature affects volumetric flow? Classical Physics 6
NASA/NACA Technical Reports and Memoranda Mechanical Engineering 6
fluid pressure difference Introductory Physics Homework 1
