Blocks, Tension, Acceleration, Friction Problem
The problem involves three blocks: Block A (8.00 kg) and Block B (5.00 kg) resting on a frictionless tabletop, with Block C suspended. The coefficient of static friction between Block A and Block B is 0.750. The maximum static friction force (Fmax) calculated was 36.75 N, leading to an incorrect mass of Block C (3.75 kg). The correct mass that Block C can have, ensuring Blocks A and B slide together, is 9.75 kg. This was determined by applying Newton's laws and analyzing the forces acting on each block.
  • Understanding of Newton's laws of motion
  • Knowledge of static friction and its coefficient
  • Ability to calculate weight and normal force
  • Familiarity with free body diagrams
  • Study the application of Newton's laws in multi-body systems
  • Learn about free body diagram techniques for complex systems
  • Explore the concept of tension in strings and its relation to mass
  • Investigate the effects of different coefficients of friction on motion
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for practical examples of static friction and multi-body systems.
trc214
Block B, with mass 5.00 kg, rests on block A, with mass 8.00 kg, which in turn is on a horizontal tabletop. There is no friction between block A and the tabletop, but the coefficient of static friction between block A and block B is 0.750. A light string attached to block A passes over a frictionless, massless pulley, and block C is suspended from the other end of the string. What is the largest mass that block C can have so that blocks A and B still slide together when the system is released from rest?
f=ma
coefficient of static friction = Fmax/normal force
At first I took found the weights of blocks A and B.
[w Block A = 8.00kg(9.8m/s^2)] = 78.4 N
[w Block B = 5.00(9.8m/s^2)] = 49 N
w of A+B = 78.4+49= 127.4 N
I calculated that the normal force of Blocks A+B = 127.4 N. Then since the weight of block C which is unknown would equal the tension in the rope, I figured I would use this information using the coefficient of friction to find the mass of block C.
So then I set 0.750 which was the coefficient of friction = to fmax/normal force.
0.750 = Fmax/127.4
I found the Fmax=36.75 N
Then I divided 36.75 N by g to get the mass of block C. I got the mass of block C to be 3.75 kg. Apparently this is incorrect and the correct answer is 9.75 kg.
Can anyone pease help me? Thank you very much.
f=ma
This is the normal force of the floor on Block A
It would only equal the rope tension if it was at rest or moving at constant velocity. Is it?
0.750 = Fmax/127.4
127.4 N is not the normal force of A on B
It may be late, but I don't get the book answer. Draw free body diagrams to identify the forces on each mass, and use Newton's laws. All blocks are accelearting at the same magnitude.
  • · Replies 47 ·
  • · Replies 33 ·
