An interesting matrix identity problem
The discussion revolves around proving a matrix identity involving two 2x2 matrices A and B, specifically that if A*B = I(2x2), then B*A = I(2x2) as well. The scope includes theoretical proofs and various approaches to the problem, with participants sharing their methods and reasoning.
  • One participant describes their lengthy proof involving the explicit forms of matrices A and B, expressing a desire for a more elegant solution.
  • Another participant suggests a method using properties of idempotent matrices and their characteristic polynomials to conclude that BA must also equal the identity matrix.
  • A different approach is presented that manipulates the equation A(BA) = A to derive BA = I, although this is challenged on the basis of assuming A has a left inverse.
  • One participant argues that if A has a right inverse, it must also have a left inverse, linking this to the properties of determinants and the invertibility of matrices.
  • Another participant notes that the proof is not as trivial as it seems, referencing the left and right shift operators and discussing the implications of having left and right inverses in finite-dimensional spaces.
  • A later reply acknowledges a similar proof given by a professor, indicating a connection to set theory rather than strictly linear algebra.
  • One participant proposes a simpler argument that shows BA is the identity on the image of B, using a contradiction based on the forms of vectors produced by B.
Participants express differing views on the simplicity and elegance of various proofs, with some asserting that certain assumptions about inverses are necessary while others challenge those assumptions. The discussion remains unresolved regarding the most straightforward or elegant proof method.
Some arguments depend on the properties of determinants and the definitions of invertibility, which may not be universally agreed upon in the context of the discussion. The proofs presented vary in complexity and familiarity with linear algebra concepts.
vsage
My linear algebra professor likes to use theorems he expects us to prove later in his proofs of theorems in class. Well it's not like that because it makes sense but they're usually more of side notes. Today he asked us to prove this:
Given A and B are 2 by 2 matrices over the field R, prove that if A*B = I(2x2) where I(2x2) is the 2x2 identity matrix, B*A = I(2x2).
Now I filled up a good page just to prove this and ended up turning A and B into
[tex]A = \left( \begin{array}{cc} a1 & a2\\<br /> a3 & a4 \end{array} \right) , B = \left( \begin{array}{cc} b1 & b2 \\ b3 & b4 \end{array} \right)[/tex]
into
[tex]A = \left( \begin{array}{cc} a1 & a2\\ a3 & a4 \end{array} \right) , B = \frac{1}{a1a4-a3a2} \left( \begin{array}{cc}a4 & -a2\\ -a3 & a1 \end{array} \right)[/tex]
and moving on from there it was pretty easy to prove that [tex]AB = BA = \left( \begin{array}{cc} 1 & 0\\0 & 1 \end{array} \right)[/tex]
Is there another way? I wasted so much time and my professor's proofs are usually so much more elegant. I can scan a copy of my work if you're still confused as to what I actually did (unbeautifully)
(Please excuse this post it will take awhile to get right I am learning LaTeX)
here's one way of doing it let me use 1 for the identity
1=AB, as given implies
B=BAB
implies
BA=BABA
let C=BA, we want to show C=1 too.
C satisfies C^2=C, so its characteristic polynomial divides x^2-x.
this implies that C is one of
[tex]\left( \begin{array}{cc} 1 & 0\\0 & 1 \end{array} \right)[/tex]
[tex]\left( \begin{array}{cc} 1 & 0\\0 & 0 \end{array} \right)[/tex]
[tex]\left( \begin{array}{cc} 0 & 0\\0 & 1 \end{array} \right)[/tex]
[tex]\left( \begin{array}{cc} 0 & 0\\0 & 0 \end{array} \right)[/tex]
but C has only 0 in its kernel, hence it must be the identity.
In general for more dimensions, we just say C is 'idempotent' since its square is itself. idempotent matrices correspond exactly to projection onto some span of some subset of the basis vectors. C has trivial kernel, and the only such idempotent is the identity matrix.
how about this:
A(BA)=(AB)A
A(BA)=IA
A(BA)=A
A^-1*A(BA)=A^-1*A
BA=I
that presupposes that A has a left inverse.
if it has a right inverse, it is invertible, and thus has a left inverse. that is, if it has a right inverse, its columnspace spans R2, which means its determinant is nonzero, which means its transposes determinant is nonzero, which means its rowspace spans R2, which means it has a left inverse. i haven't done linear algebra in a while, so i might not be thorough, but i just think there's a simpler proof of this than the one you gave.
I get the impression that they haven't yet proven that.
Mine is a very simple proof, if we omit the details, which the OP may not be familiar with.
BA is clearly idempotent with trivial kernel, hence it is the identity.
It's a one liner. Of course simplicity depends on what we assume familiarity with.
To prove that it isn't as trivial as you might think, consider the left (L) and right (R) shift operators on l^2 with the standard basis.
RL=I
so R possesses a right inverse, but R is not invertible.
It is in fact a standard lemma in group theory that if something has a left and right inverse then they are the same. However having a left inverse does not imply that something is invertible. We both need finite dimensionality.
Besides, this is a proof that applies to any linear map on a finite dimensional vector space, and does not require you to pick a basis (though I did pick one to make it clearer), and as such would generally be considered better by a pure mathematician, though if you aren't one of those you're free to think something else is better.
Sorry for being so late in responding. Yes Mattgrime my professor gave a very similar proof to that one in class. It was very set theory based as opposed to strictly linear algebra. Thank you for all your input everyone it has been enlightening :)
As usual I am too late. but this seems easy enough to do in an elementary way.
I.e. AB = I implies that (BA)B = B(AB) = B, which implies that BA is the identity on the image of B, so you just need to show that multiplication by B is surjective. Since the determinant is non zero this follows, but here is another simple argument without determinants:
If not, then every vector form Bx would have form cv for some fixed v. And then every vector of form ABx would have form A(cv) = c(Av). But not every vector x has this form, so we cannot always have ABx = x, contradiction.
  • · Replies 19 ·
