3D Boundary Value Heat Transfer with constant flux and nonzero boundary
The discussion centers on solving a 3D boundary value problem for heat transfer with constant flux and nonzero boundary conditions. The user is attempting to establish the governing partial differential equation, specifically using the Laplacian of u(x,y,z,t) and exploring the separation of variables method. They propose partitioning the solution into steady-state and variable components to address the inhomogeneous boundary conditions. The user seeks guidance on simplifying the problem, particularly in eliminating dependencies on X(x) and Z(z) while solving for Y(y).
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the heat equation and boundary value problems
  • Knowledge of separation of variables technique
  • Experience with inhomogeneous boundary conditions
  • Study the method of separation of variables in three dimensions
  • Research techniques for handling inhomogeneous boundary conditions in PDEs
  • Explore the steady-state and transient solutions for heat equations
  • Learn about exponential solutions for boundary value problems
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those dealing with complex boundary conditions in three-dimensional systems.
bnay
Hello,
I'm having trouble getting started on this problem. Here's the question:
[PLAIN]http://img810.imageshack.us/img810/2464/ee323assn3q3.jpg
My issue is in setting up the governing partial differential equation in 3 dimensions. What I've tried so far is setting du/dt equal to the Laplacian of u(x,y,z,t) + g(x,y). I'm not entirely sure if I can do this, though. It leads me to assume u(x,y,z,t) = X(x)Y(y)Z(z)T(t), but I'm not sure how to cancel out the inhomogeneous boundary conditions.
I know that if g were a constant I could let v = u - g, but since it isn't its derivative with respect to x and y won't go away and v will stay inhomogeneous.
Sorry if that sounds like word vomit - its late and I've been up reading textbooks that only seem to have one dimensional examples. If anybody could shed some light on how to tackle this problem I would be very thankful - I'm mostly looking for a starting point and hopefully I can take it from there.
timthereaper said:
If you partition u(x,y,z,t) into the sum of a "steady-state" and a "variable" portion, you might be able to make the steady state portion satisfy the nonhomogeneous boundary conditions and the variable portion satisfy the homogeneous ones. You can use a modified form for 3 dimensions of this:
http://en.wikiversity.org/wiki/Topic:Heat_equation/Solution_to_the_2-D_Heat_Equation
See if that helps.
Thank you for your help.
Setting the steady state solution as X(x)Y(y)Z(z) has worked quite well for X and Z, but for Y it seems that I don't have enough information to solve it, since I can't eliminate X(x) and Y(y) due to the inhomogenous conditions.
I know X(x)Y(y)Z(0) = g(x,y), which implies that g(x,y)/XY is a constant, but since I don't know what g(x,y) is I can't assume X or Y are constants.
I think it's safe to say that Y(y) can't be a constant since X(x)Y'(0)Z(z) = -q(x,z)/k and Y'(b) = 0
This led me to try an exponential solution for Y, but I seem to have too many variables to eliminate.
Is there any way I can simplify this to get rid of the X and Z dependence?
