Can a Vector Space Over Field F Contain Entries from Other Fields?
The discussion revolves around the question of whether the entries in a vector space defined over a field F must come exclusively from that field. Participants explore the implications of defining vector spaces over different fields, particularly focusing on examples involving real and complex numbers, and the nature of vector entries.
  • Some participants propose that entries in a vector space defined over a field F do not necessarily have to come from F, as long as the operations of addition and scalar multiplication are well-defined.
  • Others argue that while a vector space can be defined over one field, the representation of vectors may involve elements from another field, particularly in the context of complex numbers being represented as tuples of real numbers.
  • A participant provides an example of complex traceless self-adjoint 2×2 matrices, illustrating that while they can form a vector space over ℝ, they do not maintain closure under multiplication by i, thus not forming a vector space over ℂ.
  • There is a discussion about the interpretation of "entries inside the vectors," with some participants clarifying that this may refer to the components of a vector in a specific basis representation.
  • One participant emphasizes that a vector space over a field K is fundamentally an abelian additive group with a defined action of K, suggesting that the elements of the group need not have a direct connection to K.
Participants express differing views on the relationship between the field over which a vector space is defined and the entries of the vectors. There is no consensus on whether the entries must come from the same field, as some argue for flexibility while others seek clarification on the definitions involved.
Participants note that the question may involve imprecise language, particularly regarding the terms "vector" and "entries," which could lead to misunderstandings about the nature of the discussion.
zcd
Just for clarification, if a vector space is defined over a field F, are entries inside the vectors in the vector space necessarily restricted to field F? Say I had a vector space V={(a1,a2,...):ai∈C} , could the vector space be over the field R so that I only take scalars from the reals?
well,yes, but what is really your question?
My question is do entries in an n-tuple from a vector space have to be from the same field as the field the vector space is defined over?
No, they don't. And elements of a vector space don't need to be tuple. You only need to be able to multiplicate them with elements of F. But is it not necessary that elements of the vector space have anything to do with F.
However, every (finite dimensional space) is isomorphic to Fn. So in fact we are working with tuples anyway, even if we don't realize it...
A good example is the set of complex traceless self-adjoint 2×2 matrices. The standard definitions of addition and scalar multiplication give it the structure of a vector space over ℝ. But the set isn't closed under multiplication by i, so the same standard definitions do not give it the structure of a vector space over ℂ.
It's easy to show that this vector space is 3-dimensional, and that the set of Pauli spin matrices is a basis. With an appropriate choice of inner product, this basis is orthonormal.
I'm sorry, this question is so imprecise as not to make sense to me, but the others seem to know what you mean.
Are you asking whether, say the complex numbers can be considered as a vector space over the real numbers? Then the answer is yes, but in writing them down as "tuples" one would then use real numbers to represent them, not complex numbers. So the phrase "entries inside the vectors" is the part that is too imprecise for me to understand perfectly.
I.e. when you say this, I implicitly assume you mean entries in a basis representation, which do come from the base field, but that is apparently not what you meant.
When he says "vector" he means "tuple", not "member of a vector space". So he's asking if ℂn can be given the structure of a vector space over ℝ.
I'm pretty sure he means entries in the standard basis, not any other.
Not necessarily. I don't see why anyone would want to do this, but you can give ℂn the structure of a vector space over ℝ, by first defining the standard (complex) vector space structure and then restricting the scalar multiplication function to ℝ×ℂn.
The example I used in my previous post is much more interesting. It's a 3-dimensional vector space over ℝ, and the basis I mentioned looks like this:
[tex]\sigma_1=\begin{pmatrix}0 & 1\\ 1 & 0\end{pmatrix},\quad \sigma_2=\begin{pmatrix}0 & -i\\ i & 0\end{pmatrix},\quad \sigma_3=\begin{pmatrix}1 & 0\\ 0 & -1\end{pmatrix}[/tex]
So an arbitrary member can be written as
[tex]x=\sum_{k=1}^3 x_k\sigma_k=\begin{pmatrix}x_3 & x_1-ix_2\\ x_1+ix_2 & -x_3\end{pmatrix}[/tex]
Now, the tuple that you and I would associate with this vector and this basis is [itex](x_1,x_2,x_3)[/itex], but the OP's phrase "inside the vector" refers to what's inside the matrix on the right-hand side.
Sorry for not being clear with my question. I'm asking whether the field a particular vector space is over has any bearing on what's inside a vector from the vector space, or are those two separate matters?
So what you're doing is using a vector space of 2x2 matrices with complex entries, but since the scalars used for scalar multiplication are all reals the vector space is over the field of reals?
Exactly. One of the things that makes this example interesting is that we don't have the option to choose the field of scalars to be ℂ, because if A is a member of the set, iA isn't. (iA)*=-iA*=-iA≠iA.
It's the "inside a vector" part of your statement that's unclear. "Vector" means "member of a vector space", not "member of Fn, where F is some field", so it's not at all clear what "inside a vector" means. A natural interpretation would be that it's a reference to the members of the matrix of components of the vector in a given basis. In my example, that would be the real triple (x1,x2,x3), not the complex 4-tuple x.
I think the only sensible answer to this last question is "yes, the two are separate matters". A vector space over the field K is nothing but an abelian additive group with a action of K on it. The members of that group do not have to have any "connection" with K (whatever that means), only a sensible action of K on it must be defined so that the product of an element of K and an element of the group yields an element of the group.
Thanks for the clarification!
  • · Replies 18 ·
  • · Replies 32 ·
