Solve Logarithm Problem: Prove 3/2
  • Context: Undergrad
  • Thread starter Thread starter chwala
    Logarithm
The discussion revolves around proving the logarithmic equation Log(√27 + Log √8 - Log √125) / (Log 6 – Log 5) = 3/2. Participants explore various approaches to simplify the expression and verify the correctness of the problem statement, focusing on logarithmic properties and calculations.
  • One participant expresses difficulty with logarithms and attempts to simplify the expression but arrives at a different result (6/5) instead of 3/2.
  • Another participant questions whether the logarithm is base 10 or natural logarithm and suggests that the problem statement may need clarification with additional parentheses.
  • Some participants emphasize the use of logarithmic identities, such as log(ab) = log(a) + log(b) and log(a^b) = b log(a), in solving the problem.
  • A later reply indicates that the answer is independent of the logarithm's base and suggests simplifying the numerator further.
  • One participant provides a step-by-step breakdown that leads to the conclusion of 3/2, although this is not universally accepted as correct by all participants.
Participants do not reach a consensus on the correctness of the original problem statement or the validity of the proposed solutions. Multiple competing views and interpretations of the logarithmic properties remain evident throughout the discussion.
Some participants note potential confusion regarding the base of the logarithm and the clarity of the problem statement, suggesting that the expression may require more precise formatting for accurate interpretation.
This discussion may be of interest to individuals studying logarithmic functions, those seeking to understand the application of logarithmic identities, or anyone looking to refine their problem-solving skills in mathematics.
chwala
I am not very good in logs i have tried to attempt below problem in vain..give me an insight.
Prove Log(√27 + Log √8 - Log √125 ) / (Log 6 – Log 5) =3/2
I am not good in logarithms how do you show this…
This is how I did it:,
Log ( ( 3√3 *2√2 ) / 5√5 ) ) / ( 6/5)
((3√(3 *) 2√2 *5)) / ((5√5 *6)) = 6/5 and not 3/2 as indicated by problem am i right?
Is it log10 or the natural logarithm?
Are you sure the problem is correctly written in your post. If you include more parentheses it would be somewhat clearer.
You are expected to use:
log(a^b) = b log(a)
as well as some factorizing and shortening of fractions.
I checked the numerical value by typing it into Octave, but didn't get 3/2 or 6/5, not with log10 and not with the natural logarithm :-) I won't garantee that I did nothing wrong, though.
log(a^b) = b log(a)
This is a logarithms used in every day calculations i.e of base 10 and they are reffered to as common logarithms and the base 10 is often omitted...kindly note that the question is to be solved without the help of tables or other...the solution to the problem is 3/2
kindly solve manually showing your steps i have shown mine...i am conversant with the laws of logarithms.
Log ( ( 3√3 *2√2 ) / 5√5 ) ) / log ( 6/5)
Fixed.
You're trying to solve [tex]\frac{\log\left(\frac{3\sqrt{3}\cdot 2\sqrt{2}}{5\sqrt{5}}\right)}{\log\left(\frac{6}{5}\right)}[/tex]
[tex]\frac{log(a)}{log(b)}\neq \frac{a}{b}[/tex] so I'm not surprised it doesn't give you the answer you were looking for.
Look at the numerator, simplify the part inside the log, and then convert the roots into fractional powers to make things clearer :wink:
p.s. It doesn't matter what logarithm it is. The answer is independent of this.
Log (3^3/2 * 2^3/2 / 5^3/2) = Log (6/5)
Log (3*2/5)^3/2 = Log (6/5)
Log (6/5)^3/2 = Log (6/5)
3/2 Log (6/5) = Log (6/5)
3/2 = log (6/5) / Log (6/5)
=3/2
I love physics forum thank you so much…….maths for life
thanks a lot mentallic.
No worries :smile:
