New Reply
Noise Sheilding
Share Thread Thread Tools
Feb16-11, 06:37 AM   #1
Noise Sheilding
How is the noise sheilding provided by the fuselage when the engines are mounted at the rear end of the aircraft ? for example-SAX 40
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb16-11, 08:22 AM   #2
That plane isn't designed to make the cabin an ultra-quiet design, it is designed to make the plane quiet to an observer on the ground.
Feb16-11, 08:34 AM   #3
Quote by boneh3ad View Post
may be yes, but I need an explanation of how the noise is reduced when the engines are at the rear end
Feb16-11, 08:46 AM   #4
Recognitions:
Gold Membership Gold Member
Noise Sheilding
You need an explanation? Is this schoolwork?
Have you considered the difference between wing mounted engines and tail mounted? Have you looked up the noise associated with both?
Feb16-11, 08:48 AM   #5
Being at the rear end isn't going to really do anything when it comes to noise. It has more to do with the design of the engines and the fact that they are largely above the body of the plane, so the body itself will block out some of the noise. I suggest googling the SAX-40 to learn more about the specifics. Google is your friend.
Feb16-11, 08:56 AM   #6
Recognitions:
The location of the engines does play a part in how much noise there is.
Noise levels at different parts of the aircraft will vary depending on engine location.
Feb16-11, 09:16 AM   #7
Quote by jarednjames View Post
But again, the SAX-40 is not designed with cabin noise in mind, it is designed with external noise pollution in mind. Rear engines have repercussions when it comes to cabin noise, so I think it is fairly plain to see that the folks at MIT and Cambridge who came up with the SAX-40 didn't have cabin noise in mind when designing it. The rear, above-the-body position has a marked advantage when it comes to ground noise.
It has a lot of the same design concepts as those behind the Boeing X-48, only it takes thing a step further by integrating said engines into the fuselage a la the B-2.
Feb16-11, 09:25 AM   #8
Recognitions:
Blimey, thought the SAX-40 was a real aircraft (had an image of an old liner along the lines of the 717). Just Googled it and it's a concept aircraft.
Yeah, in the case of this design, if you imagine the sound waves coming off the engines they can travel upwards freely but not so well downwards. That's about as simply as it can be put.
New Reply
Thread Tools
Similar Threads for: Noise Sheilding
Thread Forum Replies
raditation sheilding question Advanced Physics Homework 1
gamma radiation sorce sheilding Introductory Physics Homework 1
noise what is it? Electrical Engineering 7
Johnson noise & Shot noise Advanced Physics Homework 4
Definition of dynamic noise and observational noise in finance Set Theory, Logic, Probability, Statistics 1
