How to Compute the Mean of a Non-linear Estimator?
  • Context: Graduate
  • Thread starter Thread starter mnb96
    Mean Non-linear
The discussion focuses on computing the expected value of a non-linear estimator defined as the minimum of N independent samples from a distribution f_X(x;θ). The estimator is represented as \(\hat{\theta}(N) = \min\{ x_i : i=1..N \}\). The solution involves deriving the probability density function (pdf) of the minimum and then calculating the expected value using that pdf. The participant successfully implemented this approach to solve the problem.
  • Understanding of statistical independence and sample distributions.
  • Familiarity with the concept of expected value in statistics.
  • Knowledge of probability density functions (pdf) and their applications.
  • Experience with non-linear estimators in statistical analysis.
  • Learn how to derive the pdf of the minimum of independent random variables.
  • Study the properties of non-linear estimators in statistical inference.
  • Explore advanced techniques for calculating expected values in complex distributions.
  • Investigate applications of minimum estimators in real-world statistical modeling.
Statisticians, data analysts, and researchers involved in statistical estimation and inference, particularly those working with non-linear estimators and probability distributions.
mnb96
Hi,
let's suppose we are given N statistically independent samples [itex]x_1,\ldots,x_n[/itex] from a certain distribution [itex]f_X(x;\theta)[/itex] depending on a parameter [itex]\theta[/itex].
We are also given an estimator for [itex]\theta[/itex] defined as follows:
[tex]\hat{\theta}}(N) = \min\{ x_i \\ : \\ i=1..N \}[/tex]
How am I supposed to compute [tex]E\{ \hat{\theta}(N) \}[/tex]?
I tried to apply the definition of mean-value as follows, but I can't go any further:
[tex]\int_{\mathbb{R}}\ldots\int_{\mathbb{R}} \min\{ x_1,\ldots,x_N \} \\ f_X(x_1)\ldots f_X(x_N)dx_1\ldots dx_N[/tex]
Any idea?
Get the pdf of the minimum, and then compute the expected value with respect to that.
Thanks.
I did as you suggested and succesfully solved the problem.
  • · Replies 21 ·
  • · Replies 0 ·
